don't know about the Korando but the Mussos are not a bad car.
They drive okay. No 4wd`s are that good on the road unless they are totally useless off road.
I did consider buying one at one point but there were two main drawbacks, first was they were slow as they didnt do a turbo diesel and the NA merc diesel has no power. You can get a turbo conversion kit for around £1300 IIRC which is supposed to make a big difference though.
The second point was the parts prices. Pattern parts are not readily available so most bits are dealer only and the prices are stupid. £1300 for an exhaust system. Engine parts are actually cheaper bought from a mercedes dealer.
They are the same as most asian cars they work out pretty good value if you are buying new with a warranty but once the warranties up its time to get rid.
