Sept 8, 2012 12:12:56 GMT
Appologies for this being a bit new, but our intergallactic mileage 320 cdi Benz has just developed the most appalling shift between 1st and 2nd gear.
Pulling away it shifts out of first and then hits a false neutral before banging into second. It's pretty much the same when shifting back down again too.
It had a fluid and filter change last year some time.
Is it toast, in need of another service, or something else entirely?
Any pointers would be good, as I can't afford to kill it!
Cheers, Joe
bl1300
Sept 8, 2012 12:58:18 GMT
First check what level is the oil at. Do you have the dipstick for the autobox as I know some mercs just had a blanking plug and the dealers had a dipstick which they charged an arm and a leg to use!
Current fleet.
Sept 8, 2012 18:05:08 GMT
Sounds like its slipping which would mean either a clutch or brake band needs replacing. Doesnt it have winter mode which will make it pull of in 2nd gear?
1992 190E 2.0 - first car, currently being driven by the wife.
1989 500SEC
1968 W115 4.2 V8
2000 CL500
Sept 8, 2012 18:17:38 GMT
Check the vacumm lines going down to the gearbox.
Sept 8, 2012 20:02:32 GMT
Sounds like its slipping which would mean either a clutch or brake band needs replacing. Doesnt it have winter mode which will make it pull of in 2nd gear? Good thinking! That would certainly be a get out of jail card until I can have a proper look! I've got a dipstick on order, so I think I'll park it up until I've done the fluid and filter just to be on the safe side. Cheers for the suggestions, Joe.
dooh
OK i had a few companies try to tell me my gearbox was shot ...has 56K ..... check to see if you have a vacuum modulator on the side or somewhere on the gearbox. It has a rubber vacuum hose coming off it. If you find it pull off the hose and see if there's any gearbox oil in it at all. If so ..you modulator has gone. They control the gearbox pressure. It sounds a little or a lot like ''low pressure '' in the gearbox possibly.The modulators have a diaphragm inside which after time go. Oil in the pipe is a clear indicator or using gearbox oil when you don't see any leaks.... ''burns out hrough the engine etc unnoticed but maybe white puffs of smoke on occasion'' ... if you have that change the modulator ''BUT'' ... don't lose the pin taking the old one out. You'll need it. Just asking .... in reverse does it judder at all??? Defo low gearbox pressure if so. Also the clutch bands maybe stretched or need adjusting ... maybe replacing due to slipping. But check the vacuum line as said first off the modulator on the gearbox ... may help you? I changed mine and at the same time done a gearbox flush with approx 12-15ltres of oil ...then just cleaned out the sump....new gasket and oil and sorted...smooth as silk :-). ... could even do a flush and oil / filter change. You should have cooler pipes from the gearbox ''possibly'' to the coolant radiator ...its normally the upper pipe. Turn off your engine and loosen the pipe if there is one ''don't know mercs'' ... get a funnel and large container then lower the pipe into it. Start the engine and tick over.....let the oil pump out until it stops add a bit more then turn off your engine. That should clear curse word out of the torque converter etc... then do the rest oil / filter / gasket and see.
74 - Triumph 2000 tc....Triumph 2500 tc Ford Tina 2.3 Ghia .... Mk2 5speed Granny 2.8i Ghia X ... 2.0ltr Granada Scorpio / 2.9 V6 12V Granada Scorpio 94 ...ohh air conned Austin maxi
Cheers dooh,
sadly mine's the electronically controlled 722.6 'box. I've been doing some digging around and it's looking like it could well be the overlap valve in the box itself. Trouble is, by the time I've shelled out on a service kit for the valve and done the oil service, it will be cheaper to buy a second hand box and chuck that in (£200).
Might have just answered my own question there, but a problem aired an' all that......
Joe
