Nick
Dec 20, 2006 14:29:04 GMT
Right, as per usual every job i try and tackle turns to utter frustration. went to do a lady friends front brakes on her fiesta and in spectacular fashion the locking wheel nut key broke, luckily it was just after i cracked off one of the locking wheel nuts. it was a flimsy design with two little bits jutting out that went into grooves on the nut. these 2 little bits have sheered off. gay. so ive only been able to do the brakes on one side, which sucks but i had to as the pads were pretty much non existant. so yeh obviously she now has no key to undo the rest of the wheel nuts on the other 3 wheels. so not only do i need a solution ASAP so i can do the other front brake, but she needs it for when the inevitable happens and she gets a flat. so yeh, where do i go about sourcing either another locking wheel nut or what can i do to get the other wheelnuts off. drill them off? i cant smash a socket onto them as the wheel nut is completely round and smooth apart from 2 little grooves. please please help, not only am i curse word off, but I'm getting earache too
this weeks car count "5"
Dec 20, 2006 14:33:14 GMT
You should be able to get a replacement key from the company that made it / them - this may take a while though.
Is there anyway you can weld a socket on to the nut?
Dec 20, 2006 14:36:05 GMT
I have this to do on one of mine. apart from your suggestion, you could try and craft something similar out of a socket etc is there no documettion for the lockers, my new ens came with a card with re order number. also defo not stored in car, in a nook cranny, boot, brace etc? ...
Nick
Dec 20, 2006 14:36:20 GMT
i have no idea who made them, not my car, and they were on the car when my friend got it, and there appears to be no markings to say who it was who made them. its a proper curse word design though.
don't think ive got much chance of welding a socket onto it tbh. someone with better welding skills perhaps.
i was hoping the answer would be get the BFH out and smash away.thats always my favourite problem solver.
I'm wondering if i can repair the damaged "key" ...
Dec 20, 2006 14:37:24 GMT
I've welded ordinary hex. nuts to lockers before but a tyre place I used to use had a set of 'sockets' with sharp serrations inside which they could knock onto nuts and would grip even a totally round fixing.
I never needed to use them because the 'weld a nut' method always worked for me.
Jet noise....the sound of freedom
Nick
Dec 20, 2006 14:40:41 GMT
hmm just been outside and luckily found the 2 flimsy curse word bits that snapped off ... dunno what material it is. i think the short answer could just be " curse word" ...might try and replace the groove with blobs of weld.
Dec 20, 2006 14:41:02 GMT
I'm sure I've seen a tool for this, either Snap On or Irwin do them IIRC, socket with sharp edges inside that dig in to the nut, even if round, grip it & pull it out. I'll keep searching & get back to you
Dec 20, 2006 14:55:17 GMT
bstardchild
Club RR Member Number: 71
Locking wheel nut helpbstardchild
@bstardchild
Club Retro Rides Member 71
Dec 20, 2006 14:59:41 GMT
Thats what I've got in a set of 4 sizes Never been beated by a locker yet and occasionally called into service for club meetings (turn up with a knackered set of lockers and a spare set of non locking wheel bolts and I'll bring me removal tool) Work very well indeed - cheap too
Nick
Dec 20, 2006 15:04:39 GMT
awesome, right I'm off to check the local motorfactors and halfrods, thanks a lot guys.
Dec 20, 2006 15:11:08 GMT
How tight was the one you managed to remove? If it wasn't last tightened by he-man could you not attack it with a hammer and chisel - try and get it to turn like?
Dec 20, 2006 15:18:30 GMT
just get an old socket and hammer it on there, don't need special tools, just a dirty great hammer. i had a knackered stud on a car once that was spinning in the hub so i undid the hub nut through the wheel and took the whole hub off so don't panic too much, its a last resort but should be easy if its still got standard wheels on it.
Nick
Dec 20, 2006 15:39:53 GMT
well being the traveller sorta bloke i am , i thought i'd try and save a few quid and have a go at making my own locking wheel nut removal tool. so yeh ive gone along the same lines as smashing a socket on there, but with extra blobs of weld in there to act as teeth. haha. i have a feeling its not going to work. if that fails I'm gonna try the hammer and chisel method.
unfortunately the other one was P*ssing tight and I'm sure thats what broke the original key.
ahwell onwardssss...
Dec 20, 2006 16:34:30 GMT
I agree with Mr P. Toaster, just attack the remains with a slightly smaller socket. It WILL work. I had the exact same thing happen to me. Brute force & ignorance will overcome.
Dec 20, 2006 16:40:17 GMT
So my question is, is there any point having lockers? the only thing it does is it puts up more resistance to crims than standard nuts. but if they want em...
Dec 20, 2006 16:41:39 GMT
A chisel has worked for me it the past but it depends on the extent to which the nut is shrouded by the wheel.
Jaguar S-Type 3.0 SE
Nick
Dec 20, 2006 16:54:10 GMT
wickedcool. my homemade craptastic specialist locking wheel nut key worked, unfortunately it worked so well its not wedged onto the wheel nut so i cant use it on the 2 at the back but i don't care, at least i can do the brakes on the front now.
thanks for the ideas guys.
all it took was a mild bit of semi-brainstorming, a welder and the big hammer.
Dec 20, 2006 19:03:13 GMT
its always worth having lockers as a couple of blokes can have the wheels off a car in about 2 mins flat without em, locking nuts slow em down and are noisy to get off.
as always you CANT stop car crime cos if they want something bad enough they'll get it, but you can make it easier for the casual tea leaf to go to next car along.
Dec 23, 2006 16:55:21 GMT
well done in removing the front one i would of suggested getting a grinder in to flatten out a couple sides of the locker, so u could grip it with something, or weld a nut onto it as someone else suggested on the previous page, (sorry cant remember who it was) but the ability to do either depends on the style of wheel fitted, steels should be easy, but some alloys with inset studs could be a real pain
2006 Audi A3 2003 Fusion 2 looking for a project....
hitman
Dec 23, 2006 18:19:19 GMT
father inlaw had a flat tyre while workin away,took it to local garage an they broke lockin wheel nut key ,they then started to cut through the alloy wheel as they said it was the only way to get wheel off :ofather in law stopped the chap an told him to blow tyre up an he drove car home I removed all 4 lockers in bout 10 mins
Last Edit: Dec 23, 2006 18:20:08 GMT by hitman
