dan90
Aug 30, 2012 17:08:37 GMT
Xe oil pump £15 posted Water pump £10 posted Dipstick and tube £10 posted Xe dizzy £30 posted xe coil £15 posted Xe cams £20 - (£30 posted) Early xe crank £20 Early xe Mahle pistons £50 Cav gsi steering rack £10 Front legs (bare) £10 each 4x 14" steel rims, no tyres (vaux) £10 steering arms £5 2 x top mount cups £15 posted early xe block £15 XE head, (not coscast) Dunno if pourous. £30 with valves/£40 with valves and cams/£20 bare
I love pie!
ishan
Aug 30, 2012 19:14:18 GMT
XE Cams- Do you also have the cam caps to go with these?
dazv8
Aug 31, 2012 11:48:51 GMT
Hi ill take the pistons if you can hold them untill end of september.cheers Daz
dan90
Aug 31, 2012 19:22:00 GMT
XE Cams- Do you also have the cam caps to go with these? What do you mean by "caps" mate? Have you got a pic. And Daz, I have 2 sets the same, one on eBay at the mo and the other I will try and save but they may be going to Brazil next week.
I love pie!
dan90
Sept 5, 2012 16:54:54 GMT
Bumps
I love pie!
Iain
Sept 6, 2012 12:15:51 GMT
XE Cams- Do you also have the cam caps to go with these? The caps need to go with the cylinder head they came off as a set, not the cams. Could be interested in the head, not sure yet, but if you're near it any time soon could you measure the height? Thanks
dan90
Sept 6, 2012 19:18:11 GMT
XE Cams- Do you also have the cam caps to go with these? The caps need to go with the cylinder head they came off as a set, not the cams. Could be interested in the head, not sure yet, but if you're near it any time soon could you measure the height? Thanks The "caps" that the lobes of the cam pushes on to move the valves? The height of the head you want?
I love pie!
Iain
Cam caps to me are the ones that you bolt the cam into the head with, not the hydraulic lifters. Yeah if you can that'd be cool
Last Edit: Sept 7, 2012 9:03:06 GMT by Iain
dan90
Sept 7, 2012 11:25:47 GMT
Ah yeah cool they will come with the head with or without the cams. I'll get it done tonight for you mate
I love pie!
dan90
Sept 8, 2012 18:34:20 GMT
the head is 8" to the top of the dizzy housing and 5 1/2" the rest of it
I love pie!
Sept 13, 2012 20:40:03 GMT
hi mate have you still got the early xe crank? if so is it rusty? text or ring for quick reply 07855659716 thanks
dan90
Sept 14, 2012 8:20:12 GMT
Yes mate it's still here and rust free, actually have 2 of them but not removed the other yet
I love pie!
