bignut
Aug 12, 2012 14:46:35 GMT
I have a problem, well I have many but lets deal with this one first! I have a Range Rover Vogue 4.6 V8 that's just had it's heads done. curse word won't start now! Crank sensor has been changed so apparently all it can be now is the immobilisor so it needs resetting, hence why I need a Rovacom. Also it needs to be local to Ilkeston, Derbys & I'll need someone to go to the car to do it. Massive ask I know but I'm stuck in Oxford & my car's at my friends in Ilkeston Can anyone help me please? :-)
Onne
Aug 12, 2012 15:00:09 GMT
Havent got the tool, but am very close by...
1990 Mercedes W126 300SE 1997 Mercedes W140 S320L
Aug 12, 2012 16:24:24 GMT
Havent got the tool, but am very close by... Go and visit... might not be the immobiliser!
bignut
Aug 12, 2012 19:52:14 GMT
onne, please tell me you're some sort of Range Rover genius! & not like me! Are you au fait with the technical side of these blumming machines? ;D
Aug 12, 2012 20:44:56 GMT
I'd be checking that new sensor....
Koos
Aug 12, 2012 22:51:03 GMT
I'd be checking that new sensor.... Same here. My 4.0 RR needed a new engine and when fitted, it wouldn't start. Turned out the "new" sensor was dodgy. Another cured the problem.
Onne
Nope, but know someone who might know...
MonzaPhil
Think like a man of action, act like a man of thought
Aug 14, 2012 21:25:59 GMT
If it turns over then it won't be immobiliser. Might have lost the sync with the key? To re-sync the key with the car either press unlock half a dozen times or put the key in the door buttons up, press left button and hold and turn key left, back up to centre (with button still down) then press right button and turn key right then back to centre , release button, do this a few times until the car locks and unlocks with the buttons. Any messages on the dash? Got T4 but a LONG way from you. Sorry
This is now a clicky linky!
10mpg
Club RR Member Number: 204
NEED Rovacom! 10mpg
@10mpg
Club Retro Rides Member 204
Aug 14, 2012 21:47:22 GMT
any normal OBD2 scanner will check the CPS, if the engine is immobilised the read out on the dash will tell you so..
check for fuel pressure by holding the schrader valve on the fuel rail open while cranking, can also help push out an air lock, have you done all the usual checks fuel compression and sparks?
I've never known a P38 need testbook after an engine swap where there was no other damage,
