Hi,
More to update you on...
Two main areas of work at the moment, rust repairs on the sill/wheelarch, and continuing with the rear light conversion
Rust
I knew the outer sill was holed near the end, but it was also very crumbly here beneath the underseal
All rusty metal cut out. Luckily the jacking point is perfectly sound, so provides an easy mounting point for the repair section
For me, the key to making rust repairs easier is to take care with accurate cardboard templates for the repair sections
Test fit of the inner sill repair, using the outer sill piece I removed as a guide
Making the lower closing piece
Weld-thru primer applied
The internal repair sections painted with weld-thru primer
Ste welding the pieces in for me
Inner sill repair fitted
Inner arch pieces welded in
All internal pieces fitted
Sprayed with red oxide primer
We welded in a 'ledge' to help form a strong joint between the original outer wheelarch and the repair section
That's as far as we got with the rust repairs, more soon.
Rear wing conversion
I bonded steel panels on the inside of the wings to block the holes for late model trims
Initial filler applied.
I found the wing had been dented, forward of the fuel filler and above the arch. It had been repaired using a thick layer of filler, 5 to 8mm over most of the panel. It didn't need this much to correct the dents, so I removed it (also enabled me to check for rust underneath, but there was none)
More phases of filler to develop the shape. The waistline trim line was difficult because the upper and lower curves (which lead to the raised trim mounting surface) have a different profile on the older panel. I used filler to make a gradual transition between the old and new profiles. This took a lot of attempts to get right!
Sprayed with filler primer. Some work still needed in a few places, but it will get there
Next update in a few days
Cheers
John
Rust
Cheers
John
