Hi Guys
I`ve got a Peugeot Expert Td that i`m fitting out as a Surf/Dayvan,
My problem is the rear suspension is really hard (because its a van) and is really harsh to drive,So much so that the rear wheels sometimes skip off the ground over speed bumps,
I thought about using springs from a Peugeot 807 (same floorpan) as i thought they may be softer but after some research the 807 is 400kgs heavier than the Expert would this be a problem or will it sort out my ride quality???
Thanks
Adrian
Thanks
Adrian
