Jul 27, 2012 12:31:25 GMT
So I'm getting a sierra 1.8 td engine and box from weblefeck on sunday to go in my 100e prefect, i know this is one of the simplist engines to wire up, but does anyone have a wiring diagram or can tell me what needs wiring up?
Also, because I'm doing my 100e to be a nice cruising car and a kind of comfy driver, I'm toying with the idea of having air con, what pumps and stuff can i use?
Nick
Nobody dies a virgin, because lifes curse word us ALL
Jul 27, 2012 12:51:22 GMT
I'll have a look tonight, I've a Haynes book for the Escort version of this engine. Pretty sure you could get AC in the Mondeo Ghia with the same engine too.
I've got Rovers.
rodney
https://www.facebook.com/RD-vehicle-transport-and-recovery-services-525622614268010/
Jul 28, 2012 15:30:54 GMT
take the aircon from a 1.8td escort mk6 , around 2000,
for the engine all you need to make it run is 1 switch live to the pump ,
facebook: rodney dean / rd transport
Jul 28, 2012 17:13:28 GMT
What about starter motor? thermostat for fan?
bortaf
Jul 28, 2012 20:01:10 GMT
The starter wiring will be the same as whats already on the 100e except there will be 1 wire left over from the 12V coil boost which you wont need to use, you'll need an ign live to trigger the glowplug relay, there is a small sub loom that also runs the cold advance on the pump but it will run fine without it both my TD converted fords do but i can copy it down if you want? it's just a live that runs to the advance solenoid on the pump VIA a resistor temp sensor near the stat. the ign live to the old coil will do for the fuel shut off valve on the pump. Rad fan TBH i allways wire in a realy and small sub loom which i can copy the detials doewn for if you want? but you will need an adpter for the top hose as the fan switch on the diesel sits in that hose not in the engine itself
R.I.P photobucket
Jul 28, 2012 23:28:39 GMT
my 100e is completely stripped and was like that when i got it so theres no wiring on it. i was gooing to do it all from new using new wires and stuff thats why i wanted a basic diagram of how to wire the engine up from what position and stuff ont he ignition IF you could copy them few bits down bortaf that would be great as every little helps thanks you
