I'm replacing my compressor so the old one is FREE to COLLECTOR ;D 60 ltr tank, classic oil type twin cylinder Westinghouse pump, unloader valve / switch but 3hp motor seized (rusted with standing under my car port over winter - might be sortable). Worked great and a real retro addition to a garage as 30+ years old ! Used to run air tools and sandblasting cabinet without a problem. Now I can weigh this in myself as quite heavy but if anyone wants it to use as originally intended (as a compressor) then I'd prefer that to be it's fate hence free to anyone who can use it. Would fit in back of hatch, or small trailer - approx 36" long, 36" high and 16" wide.
I'm at Werrington, Stoke-on-Trent.
Paul H
wayjay
Can i have this please
animation/50824d1161949630-ford-capri-2-8i-capri_062.jpg
Can I have this please Yours if you want it. Better it gets used than scrapped as still years of life left. PM me your email address and I'll let you have directions for collection. paul H
Jul 26, 2012 20:15:34 GMT
Can I have this please That was very polite Instead of the usual ' I'll take it off ya hands' Soak the bore with some diesel and leave it a few days, turn her over by hand and that should free it up. If not just strip the head down and clean everything up. Gd luck with it.
2 X Rover 'Wedge' 400's
Montego 2.0 MDi Countryman
1996 Rover 216 Cabriolet
Rover 75 V6
2002 45 K-14 Impression
*WANTED* - Crypton Cadet System 700 - PM with details.
Colin
Jul 26, 2012 20:53:46 GMT
If for some reason the above doesn’t work out I’d like to take this off your hands to try and sort. Was looking to buy one but simply can’t afford it at the moment. Collection is no problem
If it is possible can I get 3rd bagsy on the please?
wayjay
Can I have this please That was very polite Instead of the usual ' I'll take it off ya hands' Soak the bore with some diesel and leave it a few days, turn her over by hand and that should free it up. If not just strip the head down and clean everything up. Gd luck with it. I got the compressor home and turned the motor with stilsons after some wd40 and it freed off easily,works great but bearings are noisy,thanks again Paul
Nice one. Have you had chance to use any tools with it yet?
Rover 75 V6
wayjay
Yeah used it to underseal my astra van
