The Doctor
Club RR Member Number: 48
Jul 14, 2012 21:38:55 GMT
The Corolla is in for a diff change atm, because i couldn't live with the short ratio final drive any longer. This evening I've been calculating some stuff with the online calculators, but i don't get a match with the reality. With the 4.3 final drive i have now and 205/60/13 tires, my max speed on the satnav is 185 (redline 7500 rpm), but the online calculator says i should reach 210 at 7000 rpm. Clicky picky for bigger version, i played with tire sizes and diff ratios a bit, but the little thing doesn't like the tire size change, so on the right graph there are 2 different tire sizes, even though it only states 1. en here's the calculator i used. Is there something I'm missing? I know the ratios are correct (only the 5th gear is a little off, it should be 0.861 in stead of 0.843, but that won't make a 30km/h difference). I just can't understand the huuuge difference between the reality and what this calculator tells me, andi want to understand it, can anyone shed a light?
Jul 14, 2012 21:48:07 GMT
I dunno quite how much they are out but sat navs are not 100% accurate, civilian ones have built in inaccuracies, also most of them do not correct for you changing your height above see level so you need to be on a perfectly flat road or the speed will be even further out.
The Doctor
Jul 14, 2012 22:01:33 GMT
well, satnav tells me i'm doing 185 km/h while the calculator says I should reach 210 easily. And on the smaller tires i've used for a couple of weeks i'm only reaching 162 km/h, and calculator tells me 198 should be possible.
Last Edit: Jul 14, 2012 22:02:32 GMT by The Doctor
Jul 14, 2012 23:00:25 GMT
Well this one agrees with your one, somethings odd with your satnav or rev counter unless you your numbers are wrong on your gearing? Are you going on figures given to you for 5th gear and Fd ratio or have you marked them up and counted the revolutions? www.catherineandken.co.uk/sti/tyres.html
The Doctor
Jul 14, 2012 23:13:19 GMT
there is only a couple of gearsets available for my gearbox, and even the super rare close ratio gearset has a very similar 5th, so i'm pretty sure that ratio is fine. The final drive came out of a completely stock car, with the VIN tag still in place which stated that it should be a 4.3:1, if the speeds my satnav tells me are correct, it should be a 5.1:1 ratio, and i'm not even sure they made them in the size my diff is, let alone the chance of finding one in an original car! 5.1:1 is not a ratio i'd expect in anything else then a racing car.
Revcounter should be correct, i don't see it sticking or waving, and the speed and revs do go up in the same way in every gear. And when my rev counter sits at 7500 rpm, it really feels like that.
So that does indeed leave a dodgy GPS (which i didn't think could be possible for such a HUGE difference) or i've some super rare short ratio final drive, but i'll try to find out when i get the car back from the shop.
Why are you driving so fast in a Corolla? Is it a racing car? I would have thought that even for track days, 185km/h should be plenty of maximum speed for most circuits.
What? 185 kph isnt fast?
I cruise faster than that in my old volvo estate car on the motorways and i still have to move out of the way of faster cars.
The Doctor
Why are you driving so fast in a Corolla? Is it a racing car? I would have thought that even for track days, 185km/h should be plenty of maximum speed for most circuits. my trackday tires are a little bit smaller then the normal tires i use on street, that means i run off the clock somewhere near 3/4 of the straight. And the German autobahn is unlimited and only 2 hours away, so every now and then we hop over the border to do a topspeed run with a couple of mates to see if our modifications worked or not
I had a similar head scratching moment calculating S2000 gear ratios. turns out on the S2000 the gearbox ratios are not what goes in one end and out the other but direct ratios. in the calculation there also needs to be another ratio which is a reduction ratio from the input shaft of 1.16 to one. took me a while of googling to find this info out. using simple maths will help find your problem engine rpm - 7,500 (A) 5th gear ratio - 0.861 (B) axle ratio - 4.3 to 1 (C) rolling radius for 205/60x13 - 1.81 meters (D) (found online) to find the rpm of the wheels (A) divided by (B) is propshaft rpm (E) (E) divided by (C) is wheel rpm (F) (F) times (D) is distance travel'd (G) in one minute in meters divide (G) by 1000 to get KM/minute then times 60 to get KM/hour so (A) divided by (B) divided by (C) times (D) divided by 1000 times 60 = kmph so simply put 7,500 divided by 0.861 divided by 4.3 times 1.81 divided by 1000 times 60 which equals 219 kph to get mph divide by 8 then times by 5 = 137 mph either there is another ratio to take into account or as you say you don't have the axle ratio you think you have edit this is the ratio calculator with the reduction ratio showing for the S2000. sadly only lists a few gearboxes
Last Edit: Jul 15, 2012 9:52:24 GMT by Bozwell
Have you plugged in a calibrated rev counter?
rev counters can be hugely off!
The Doctor
i've looked at pics from the gearbox at google and this is one i found: so the extra ratio you're talking about, is the one going from the bottom shaft back up to the output shaft or the one on the input shaft? Could be the case indeed, but strange that it's NOWHERE mentioned, and i think every gearbox works about the same, right?
Jul 15, 2012 10:01:14 GMT
Two possible layouts: like above, 4th gear as input, or input directely via the laygear/counter shaft.
Jul 15, 2012 10:01:36 GMT
going backwards on the maths 185kph is 6,306 rpm
what gearbox do you have .
Last Edit: Jul 15, 2012 10:02:22 GMT by Bozwell
The Doctor
Jul 15, 2012 10:04:34 GMT
Toyota T50 First Gear: 3.587:1 Second Gear: 2.022:1 Third Gear: 1.384:1 Fourth Gear: 1.00:1 Fifth Gear: 0.861:1 And if this info is correct: www.my-acoustic.com/Car/gearbox/working/working.htm4th is prise-direct (or how it's called..) and then the counter shaft is put out of work, right? The more i look into the whole gearbox thing, the more it confuses me...
Last Edit: Jul 15, 2012 10:05:53 GMT by The Doctor
Jul 15, 2012 10:15:15 GMT
4th is prise-direct (or how it's called..) and then the counter shaft is put out of work, right? That's how it works, yes Or in other words, the main shaft is a two-piece construction. With power input via the countershaft, it can be build as a single piece. Yeah, it's confusing at first, but once you 'got into it' it's very simple mechanics
Jul 15, 2012 10:19:08 GMT
since 4th is 1 to 1 and looks like it just locks the shaft straight through i'd say there isn't a reduction ratio.
check rev counter then check axle ratio.
Jul 15, 2012 10:29:57 GMT
4.3 is still a very short axle ratio anyway. i have a 3.54 with slightly smaller rolling radius which is a good compromise between road and track use with a 7000 rpm red line. 3.77 would be slightly better for the track.
RobinJI
Jul 15, 2012 15:58:23 GMT
since 4th is 1 to 1 and looks like it just locks the shaft straight through i'd say there isn't a reduction ratio. check rev counter then check axle ratio. There wont be a reduction ration in 4th, but there will be in 5th where the counter-shaft comes into play. I'd be guessing that's where the problem's come from. Can you do a top speed run in 4th? It'd allow you to check the final drive without the gearbox screwing with your sums.
Jul 15, 2012 16:41:01 GMT
if there was a reduction ratio it would be on all gears. the reduction ratio is seperate from the gear ratios when a gearbox has one (the S2000 gearbox being a good example). the T50 doesn't have a reduction ratio so it's simple maths to work out the top speed in any gear. the reduction ratio is 1.16 to one on the S2000. why they don't just give the input to output shaft ratios to stop a lot of confusion i don't know . would make things a lot simpler.
RobinJI
Jul 15, 2012 17:23:01 GMT
If you look at the box in the picture posted higher in this page I'm pretty sure it does have a reduction ratio in 1st/2nd/3rd/5th, as the drive is traveling to the counter shaft through the gears labeled A and B, which don't appear to be the same size, but when 4th is selected this is taken out of the picture, as the counter shaft isn't being used.
