Hi guys,
I've a 2cv engine, 602cc sitting on a pallet outside my garage.
It's been sitting a while, but it's not seized, I was able to crank it a tiny amount with the starter handle.
I want to wire up the starter motor to get it turn over, and get some oil through it.
The starter motor is pre-engaged type. What do i connect up and to where?
There's 2x 11mm or 13mm and 1x 8mm bolt.
I'm assuming 1 is an earth?
I can go grab a pic of it if need be!
