I'm getting a bit sick of my steel wheels rusting. I quite like the 'arcitecture' of a steel wheel and feel they add some authenticity to the car (van) Ideally i'd like some alloys which look like steels so they go relatively unnoticed but don't rust! The van is a Citroen Dispatch and has a pcd of 5x98 So far the nearest i have found are alloys fitted to Alfa GTVs, like Citroen C5s had plain looking alloys (rather like Halford's hub caps) so quite lucky they're 4 stud Has anyone got any ideas? ATS cups come to mind but i don't suppose they are in the right PCD or at a bargain price.. Ta,
That's interesting..... Audi do some steel-like alloys, don't they? Hmm, 5 x 100 and centre bore of 57. Centre could be enlarged to 58. Now I wonder what the ET is..
Cant say Ive ever had an issue with rusting wheels? If they get that much abuse wont alloys just corrode as well?
Its probably more work to keep alloys looking good than it is to slap some fresh paint on a set of steels occasionally or am I missing something?
No, it's just that steel wheels rust and alloys don't If you look at most >5 year old vans the wheels are rusty, unless they've had a quick once-over with the spray can to get them sold, then the rust is back in a week The wheels on my van were rusty so i stripped them back, removed the rust and painted them and it's starting to come through again. Maybe i didn't do a good enough job at removing it in the first place but i did the best i could with the tools i had, mainly a wire brush attachment, and that's the point really. i don't want to go back to that I do see why production alloy wheels would need much attention? Anything up to 10 years old should hold it's finish etc? Shouldn't it?
Strip the steel wheels back, remove the rust, then the key to the success - Bilt Hamber them, then repaint. Did this on the panda steels and they still look good.
1993 Fiat Panda Selecta 2003 Vauxhall Combo 1.7DI van 2006 Mercedes Kompressor Evolution-S AMG SportCoupé
"You think you hate it now, wait til you drive it"
just get them blasted and powdercoated
Alloys pit and corrode much as steels do, the colour difference isn't as immediately obvious I'll grant you but they still need cleaning.The alloys on my volvo are painted and have stayed looking fine all year, the ones on our truck are polished and need redoing every month or so or they go very dull and scabby looking.
Its the paint finish rather than the material i reckon, either one will go manky if the paint (or lacquer) lifts.
bortaf
No, it's just that steel wheels rust and alloys don't If you look at most >5 year old vans the wheels are rusty, unless they've had a quick once-over with the spray can to get them sold, then the rust is back in a week The wheels on my van were rusty so I stripped them back, removed the rust and painted them and it's starting to come through again. Maybe I didn't do a good enough job at removing it in the first place but I did the best I could with the tools I had, mainly a wire brush attachment, and that's the point really. I don't want to go back to that I do see why production alloy wheels would need much attention? Anything up to 10 years old should hold it's finish etc? Shouldn't it? sorry don't meen to sound harsh (but i will i guess) but thats rubbish, alloy corrodes faster than steel it's just they have a protective covering of paint and or laquer on them. Never had a problem with rusty steel wheels and if i did a decent paint allways sorts it out the same as it does on alloys, i spose the only pluss point is alloy corrosion is the same (ish) colour as the non corroded alloy, i have steel wheels on my P100 and they are 23 years old and no rust. appart from a V V small patch near the balence weights I'm not against steel looking alloys in fact on the right vehical they can be pretty dam cool and subtle Lots of alfas share that 5X98 also lancias (delta) pug 806, not sure on the ET but have a look here www.carlsalter.com/all-wheel-fitments.html
R.I.P photobucket
Rich
Club RR Member Number: 160
Alloys that look like steelsRich
@foxmcintyre
Club Retro Rides Member 160
Citroen/Peugeot C5/407 'steels', made of alloy, look like pressed steel. Shame I think they are only available as 4x108 PCD
kevfromwales
the conrod's REALLY out the block now!
^^ nope, iirc you can get them in 5x108 too, but I'm buggered if I can remember what they came on!
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
bortaf
XM or a jumper ? seems to be the only 2 listed on that link i posted with 5X108 ?
R.I.P photobucket
mylittletony
Club RR Member Number: 84
Alloys that look like steelsmylittletony
@mylittletony
Club Retro Rides Member 84
Citroen/Peugeot C5/407 'steels', made of alloy, look like pressed steel. Really?? they look a lot like they are pressed steel... they have a thin (thickness of steel strip, ~3mm) lip, the mounting flange has strengthening profile pressed in it etc. Plus why would a manufacturer cast an alloy wheel to then hide it behind a hubcap? unnecessary additional cost when alloys are 'more desirable' anyway I'd be very intrigued to be proved wrong on this, have you tried a magnet against them?
They are the real deal, I clicked on this thread to suggest them. Pretty rare though and fetch decent money second hand.
I've got Rovers.
mylittletony
@mylittletony
did a bit of reading up as well, I stand corrected... still seems a very odd thing to do, but then this is Citroen we're talking about!
I think its more an unsprung weight saving exorcise that anything else..
I think its more an unsprung weight saving exorcise that anything else.. I was going to say weight saving / MPG.
kevfromwales
^^ they are spare wheels chaps I know - they came from out of the kfw wheel stash edit - the 5x108 ones are iirc out of a pug of some sort - can't remember what though, and I've never actually had one 'in my hand' so to speak
Guessing 5x98 > 5x112 might be a bit of a stretch, but I always thought these Mercedes rims looked a bit like steels. They're forged alloy, but the shape mimics a traditional steel wheel in places. Dimensions are 16x7 ET37. I bought a rough set a few years back stripped them down then painted them Peugeot Graphite Grey. There's a wider version (16x7.5) that really suits satin black: HTH
Last Edit: Jul 6, 2012 17:18:03 GMT by 0rangepeel
