run into a problem with the lada, getting the hubs to ford pcd. there jsut isnt room to redrill to a larger pcd than 4x100, but neither is there room for a spacer.
so I'm looking to swap some different hubs on there, prime candidate would be capri ones so i can go to vented discs. has anyone got a set laying round they can measure up for me? i need bearing IDs on the spindle for inner and outer bearings, bearing spacing, hub flange offset, etc.
