Jun 27, 2012 15:28:00 GMT
I'm trying to get my Fiesta on the road, it drove into a garage 8 years ago and hasnt moved since. It just failed an MOT due to the emissions...they were off the charts ![:(](//storage.proboards.com/forum/images/smiley/sad.png) I need some advice on getting them down. This are all the things that I have changed on it so far: New distrubutor cap and rotor arm New HT leads and spark plugs New fuel pump New air filter Oil change and filter Used Redex to clean the carb One of the first bits I want to know which might help a lot is which way should I turn the fuel mixture screw to get less fuel?? After that I'm a bit stuck so any suggestions? ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Jun 27, 2012 17:20:51 GMT
It needs a good blast down a motorway or the carb setting up
Jun 27, 2012 18:24:22 GMT
1) Set valve clearances.
2) Change oil. Oh, you've done that one. Did you use the right grade?
3) Set points gap (having checked condensor and made sure you're getting a nice big blue spark).
4) Set ignition timing.
5) Set idle mixture.
6) Italian tune-up (get it properly hot and thrash the nuts off it for a few miles).
7) re-visit ignition and mixture.
If you don't know how to do these things, pay a garage (preferably a classic car specialist, with a "well established" mechanic) to do it for you. Nothing there is particularly hard, but if you don't know what you are doing you'll only make things worse.
Jun 27, 2012 18:28:20 GMT
does the crank vent into the airbox?
RobinJI
Jun 27, 2012 19:58:27 GMT
What James said.
Did it fail on hydrocarbons or CO2?
Last Edit: Jun 27, 2012 19:58:49 GMT by RobinJI
Jun 27, 2012 20:20:27 GMT
1) Set valve clearances. 2) Change oil. Oh, you've done that one. Did you use the right grade? 3) Set points gap (having checked condensor and made sure you're getting a nice big blue spark). 4) Set ignition timing. 5) Set idle mixture. 6) Italian tune-up (get it properly hot and thrash the nuts off it for a few miles). 7) re-visit ignition and mixture. If you don't know how to do these things, pay a garage (preferably a classic car specialist, with a "well established" mechanic) to do it for you. Nothing there is particularly hard, but if you don't know what you are doing you'll only make things worse. Valve clearances were done but yeah i'll look at the others. its just a pain it aint taxed cause I'm a bit reluctated to take it out on the road for a proper drive. Robin - it failed on both massively! 9.99% on Co2 and i cant remember what he said on the hyrdocarbons but for some reason 3000 comes to mind!
RobinJI
Jun 27, 2012 20:25:17 GMT
Sounds super rich. Unfortunately I know nothing about the carbs on these! Hopefully someone who does will be along soon.
Jun 27, 2012 20:31:06 GMT
Is the choke working properly, if its had a manual conversion is it pushed all the way in?
bortaf
Jun 27, 2012 21:00:09 GMT
IME the carb will be full of laquer from the old fuel and to shift it you really need to strip the carb and blow out all the passages with carb cleaner, pluss the usuall susspects are choke not fully off and the crank vent blowing oil fumes into the inlet, you can just re direct this into a catch can if it's the problem and block off the manifold pipe.
R.I.P photobucket
Jun 27, 2012 22:10:07 GMT
9.99%? Ignition WAY too far advanced. Get a timing light on it! I'm guessing that the plugs are black and there's soot/smoke from the exhaust too.
Jun 27, 2012 22:58:35 GMT
9.99%? Ignition WAY too far advanced. Get a timing light on it! I'm guessing that the plugs are black and there's soot/smoke from the exhaust too. I'm with James although I'm upping his 9.99% to a whopping 99.99% ....based on what I've seen of Mk1 Fiestas and James' knack of getting them running sweetly!
Jul 18, 2012 14:10:26 GMT
no smoke and the spark plugs are new. Just changing the points on it today and once ive sorted the brakes i'll take it for a drive.
djefk
Jul 21, 2012 13:33:33 GMT
What year of car did emissions become compulsory for on the MOT as I thought it was around 1983 onwards?
Last Edit: Jul 21, 2012 13:34:19 GMT by djefk
Rich
Club RR Member Number: 160
Lowering Emissions Mk1 FiestaRich
@foxmcintyre
Club Retro Rides Member 160
Jul 21, 2012 15:03:51 GMT
What year of car did emissions become compulsory for on the MOT as I thought it was around 1983 onwards? I recall 1st of august 1975.. Before that it has to have a visual smoke emissions test, after '75 its onto the gas analyser!
grahamj
Old enough to know better....
Jul 21, 2012 20:35:00 GMT
4.5 per cent on Co's upto a date in the 80's (which i cant remember!) 3.5 after..? Sounds like carb is knackered to me, what make is it ?
2005 VW T5 Dayvan 1997 VW T4 Dayvan Vauxhall Nova 2 Litre Redtop 1970 Moggy Van.. 94 vw Passat Bus 1985 Vauxhall Nova Base show car 1987 Vauxhall Nova 1.4 16v XE Rallycar
Jul 28, 2012 12:03:06 GMT
Is a weber carb, not sure on the actual spec though. Just changed the points which has helped a bit but for some reason the idle won't stay steady. Get it set right and then a min later is out again, either running fast or just dies ![:(](//storage.proboards.com/forum/images/smiley/sad.png)
Jul 29, 2012 20:46:08 GMT
Hi, you say it has been stood for 8 years. Is it possible you have a leaking head gasket? Antifreeze has a habit of separating from the water if a car is stood for a long period of time. Then you get corrosion in the head gasket as well as core plugs, aluminum castings and the cast steel. This would play havoc with emissons. Which engine type/size is it?
Jul 29, 2012 20:51:14 GMT
got fresh fuel as well? that'll help too ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
bl1300
Jul 31, 2012 13:44:22 GMT
Time to get the timing light out. Leave the mixture screw alone untill you know the timing is correct otherwise you may well make things worse.
Out of interest does it have a CAT?
Current fleet.
Brian Damaged
West Midlands
Club RR Member Number: 33
Jul 31, 2012 14:01:53 GMT
Out of interest does it have a CAT? Cats weren't fitted on UK-spec Fiestas until 1992.
