Some starter solenoid advice please.
Modern BMW engine into a Triumph, the Triumphs starter motor had it's solenoid mounted on the wing near the near engine.
Is the barrel shaped thing on top of the BMW starter motor with 2 large terminals and 1 smaller one the solenoid?
And it's wired in essentially the same way as the Triumph one?
The BMW had a 5 amp fuse labelled “starter”, this is for the solenoid, not the starter motor? And is it worth adding a relay from the starter switch to the solenoid?
Thanks, just need a thought process reality check!
