Jun 22, 2012 20:49:55 GMT
thinking of fitting a vauxhall twincam engine into my car and want to use the 5 speed box which i have fitted .ZF
now the engine at mo is a 2.0lt cih (manta) running twin carbs
been offered a 2.2 twincam out of a omega
will this fit directly onto the ZF box or will I need an adaptor plate made up.
`state
Yorkshire and The Humber
Jun 22, 2012 21:19:49 GMT
No it wont fit direct but an adaptor plate should see you right.Cant you use the omega box too to save faffing about?
Look at all the plastic people who live without a care.Try to sit with me around my table,but never bring a chair.
Jun 23, 2012 19:39:51 GMT
i could but need to sort out speedo as omega box aint got 1
Jun 23, 2012 22:10:26 GMT
would'nt be sorting a speedo feed from the prop/cv joints be easier than fabricating a bellhousing?
Jun 24, 2012 10:01:52 GMT
So you have 4 choices,
adapter plate,
omega gearbox with some means of driving a speedo, and possibly tunnel mods, as its a huge box,
carlton box, as huge as an omega, but has speedo drive,
Manta 1.8 gearbox, small has speedo drive, not as tough and fairly rare now.
Jun 24, 2012 12:35:28 GMT
thanks lads . which carlton box would I need .
got no problem with space as the whole tunnel has been removed to re-fabricate .
not that clued up on vauxhall more of a ford guy lol..........
