Shortcut
I won't be there when you cross the road, so always use the Green Cross Code.
bye bye tarmac spec struts and springs hello full coilover conversion and tarmac springs going down? lowered pics when daylight, car and me are joined as one!
This space available to rent. Reach literally dozens of people. Cheap rates!
WOOO good work!
Nov 23, 2006 10:37:22 GMT
Wow, nice one!
Nov 23, 2006 11:16:29 GMT
You appear to have the spring platforms wound up to the wrong end of the strut. Please correct immediately...
Nov 23, 2006 13:00:56 GMT
did you make these yourself, if so was it easy enough, must say well done, looks top, lash those threads in copper or waterproof grease tho!
Mini 998cc grp bonnet & boot, lightend shell, 6-point cage, soon to have a turbo on the 998 engine (t2 frm a r5gt) rs turbo intercooler, hoping to get 120ish bhp?
father is building a Mini Van 1330, 45 weber, 100bhp@wheels
'RIP' 1.8 Metro GTi, 15.23 1/4mile
Nov 23, 2006 13:12:12 GMT
It's daylight. Where are the pics?
There is nothing more expensive than a cheap Mercedes
Shortcut
Nov 23, 2006 13:31:15 GMT
ha ha
Me office, car home, camera lens not THAT long!
Yes they are wound up to forrest hight at the mo, makes it look a bit odd, but with the big flappy flaps it looks like a proper rally car not a slammed street car. Lowering will load up the springs and make it even stiffer which my back can't rally cope with. I WILL slam it just for the pics as I know you want to see it.
Not hard to make. Grind off original spring platform, leaving just enough for the sleeves to rest on and enough to tack the welds too as you can't weld onto the strut cos you knacker teh viscosity of the oil. 3 welds to hold it all in place, grind them down smooth and add red oxide to protect.
I must say the coils look ridiculously small (diameter) compared to the old ones but they are 150lb and so were the old ones. 130 on the rear.
Nov 23, 2006 13:49:25 GMT
You appear to have the spring platforms wound up to the wrong end of the strut. Please correct immediately... My thoughts exactly! Nice work
Nov 23, 2006 13:58:28 GMT
i think i'll make these for my triumph saloon as my front shocks are knackered & the struts take inserts, by your description & the mag articles i have i think i may go this route, seems a worthwhile mod for only a small bit of extra effort, hope the bolts that hold my dampers in my struts come out without too much effort, i bet they'll be a complete though! haha the joys :OP
Shortcut
Nov 23, 2006 14:20:54 GMT
I was lucky as I had replaced the original struts with the uprated ones only last year so all teh bolts were still easy peasy.
