Jun 16, 2012 19:12:42 GMT
Hey all, ive just bought a merc sprinter as a support van for track days,i need at least one window put in it,whats the best rubberor bonded windows? And does anyone know a good fitter in the bristol area or somewhere i can buy the kits as I'm handy with an anglegrinder Cheers Gaz
Jun 16, 2012 21:17:51 GMT
For my Peugeot van I used Leisure Vehicle Windows as they were the cheapest. www.leisurevehiclewindows.co.uk/Easy to fit the rubber type. I made a template out of brown paper a few mm larger than the window and attached that to the vehicle before cutting out with jigsaw. Paul H
BiAS
Insert witty comment here
Club RR Member Number: 147
van windows, rubber or bonded??BiAS
@cheeqi
Club Retro Rides Member 147
Jun 17, 2012 19:06:21 GMT
I do this at work, I'd say bond ins if you can, much more chance of getting them water tight than clayton-wright rubber in type. Coventry Vehicle Windows seem to be one of the cheapest places for us.
(car+wheels)-rideheight=WIN
ruffgeezer
Attracts french tat.
Jun 17, 2012 19:50:25 GMT
Silly question, could you not chuck a slidy door in with the window already fitted? Saves chopping it about, and should guarantee a seal?
Jun 17, 2012 19:56:43 GMT
Bias, do you actually fit windows then?
'90 Audi B3 Coupe 2.3 Auto [gone] '92 Audi S4 Avant 2.2 AAN Turbo Auto [gone] '93 Audi 80 Avant 1.9TDi [gone] '96 Audi A4 Avant 2.6 Quattro [gone] '97 VW T4 1.9td LWB [gone] '03 Skoda Octavia 1.9TDi [gone] '05 VW T5 Shuttle LWB 1.9TDi '15 VW Caddy Maxi Kombi 1.6TDi
cheers all, was thinking of going down the bonded route, just need to find a place local that can supply the window as I don't mind getting the air saw out
I used to work at a company which did van side window conversions, used to just cut out the panel and fit merc rubbers and window, very easy to do too, I don't know of any bonded side windows on a sprinter from the factory but I do lots of mini buses that have them but they sit on the outside of the panel ( about 5mm ) and imo look ugly and are prone to being damaged due to the way they sit on the panel, hence why I do lot's of them,( although it could be down to the drivers? ) go for rubber one's and paint the bare edge before you fit the window, the Met police have bonded and bolted one's but i don't think you will be able to get any of them unless you come across a decommissioned sprinter, they are also polycarbonate, if you are worried about security bond the rubber to the body and glass once the window is fitted but get the window security filmed before the window is fitted, make sure the film goes to the very edge as it will all be held in place if it is broken.
Last Edit: Jun 18, 2012 9:15:36 GMT by rusty998
MK2 Cortina Estate
Jun 18, 2012 11:28:22 GMT
You need 70s porthole windows, Shirley?
Jun 22, 2012 19:00:49 GMT
nice
