Jun 16, 2012 12:20:29 GMT
this may seem like a dead amatuer question and I'm sorry. passed my driving test 3 months ago and hopped straight into my viva of which the fan belt sqweeled everywhere to the point i had to get bumped out of the petrol station (highly embaressing) after this ordeal i replaced the belt. However since replacing it it squeels on start up for about 15 seconds and then stops, it also squeels when I'm driving in the rain and it will also squeel with the lights on or with a car full of people, obviously the harder it has to work the more it will squeel and its just dead annoying and embaressing. what should i be doing, loosening/tightening/powdering
any help would be great thanks
1988 manual w124 230ce
1970 manual series 1 xj6
1974 viva sl
1990 mk4 twin carb civic (sold)
1983 carlton estate (sold)
Jun 16, 2012 12:59:09 GMT
the belt probably just needs a little more tightening, not to tight that it destroys the alternator bearings, a new one will stretch initially!
if the engine is well worn, you can get to the point where belts bottom out in the V of the pulleys, so never get tight enough, or worn alternator bearings can mean that the belt slips, but just try tightening the belt first, just a little mind!
Last Edit: Jun 16, 2012 13:00:30 GMT by ianboyd
Jun 16, 2012 14:13:55 GMT
My old fiesta used to go through alternator belts loads. The next owner told me the alternator was a tiny bit out of alignment so didn't really tension the belt properly. If the belt is old and feels hard and plasticy or is perished you should replace it- a fresh rubbery one will grip far better and you won't be risking it snapping as much
VIP
Jun 16, 2012 16:13:42 GMT
There should be no more than an inch of total deflection [movement up and down] when pressing/pulling on the centre of the longest length of belt between two pulleys.
That's how I was taught anyway.
Jun 16, 2012 16:52:26 GMT
Agreed Dan. it can also be an early sign of a failing water pump. Is it beginning to dribble any water- are there any rust stains arounds it? Not always the case- but it can be a good indicator
bl1300
Jun 16, 2012 17:02:34 GMT
There should be no more than an inch of total deflection [movement up and down] when pressing/pulling on the centre of the longest length of belt between two pulleys. That's how I was taught anyway. ditto that. It does sound very like the belt has stretched and needs tensioning
Current fleet.
Indie
Wtd : Carlton/205 bits
Jun 16, 2012 20:54:49 GMT
As above - check tension and alignment of the pulleys and it's always worth cleaning the inside of the pulley where the fan 'grips'.
bortaf
Jun 16, 2012 21:34:53 GMT
this may seem like a dead amatuer question and I'm sorry. passed my driving test 3 months ago and hopped straight into my viva of which the fan belt sqweeled everywhere to the point I had to get bumped out of the petrol station (highly embaressing) after this ordeal I replaced the belt. However since replacing it it squeels on start up for about 15 seconds and then stops, it also squeels when I'm driving in the rain and it will also squeel with the lights on or with a car full of people, obviously the harder it has to work the more it will squeel and its just dead annoying and embaressing. what should I be doing, loosening/tightening/powdering any help would be great thanks Seeing as it's a new belt and assuming it is not loose check for a seized heater motor, silly i know but i had this before and when the fan was on the drain on the alt allomost stalled the engine due to the load on the alt slowing it, a short somewhere unprotected by a fuse will cause it as well, usually the starter motor.
R.I.P photobucket
Jun 19, 2012 12:11:35 GMT
normally driving along without lights on with the radio on in normal weather is totally silent, i will nip it up a bit and give the runners a scrape out and clean up and see how it goes, really hope its not something possibly terminal or costly thanks for the help everyone!
1974 viva sl
