Jun 14, 2012 16:37:48 GMT
How much wobble does a wobble bolt have? I.e. how much difference can there be between the pcd's and still be safe? Would they 'do' 2mm or 4mm? Ta!
Koos
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Jun 14, 2012 16:53:16 GMT
1mm each bolt, ie 2mm on PCD is generally accepted as being the 'safe' maximum
Jun 14, 2012 17:02:26 GMT
1mm each bolt, ie 2mm on PCD is generally accepted as being the 'safe' maximum Cool, thanks ;D Is there a good place to get them. I vaguely remember a bolt guy or someone...
Last Edit: Jun 14, 2012 17:21:52 GMT by mdh
Koos
Jun 18, 2012 18:36:33 GMT
Bumping this as it saves a new thread. May also be of benefit to the OP, too Is the 2mm my absolute limit? Let's say I run an absurd old British car with 3.75" PCD. Or 95.25mm, and going up to Fiat 4x98 would open a whole world of different wheels.. Would I be able to wobble the 2.75mm? And are they wobble nuts available in 3/8" UNF??
MrSpeedy
East Midlands
Jun 18, 2012 18:46:41 GMT
It may be worth considering PCD adaptors, asuming your obscure old British car with 3.75" pcd is rear wheel drive (Triumph?) as the diference between RWD offset and FWD offset lends itself very nicely to accomodating the thickness of the adaptor
Jun 18, 2012 20:20:11 GMT
It's a Standard Ten.
Just pondering at the moment but I think you are probably right that adaptors would be a better bet.
