boo
Jun 13, 2012 19:26:43 GMT
suddenly my rover 25 wont start . went to the shops in it after work locked it up . came back out to go home car wont start . theres power there the immobilisers working as it should every thing else works it just wont turn over . any ideas any one
hamps
www.medwayrscentre.co.uk
Jun 13, 2012 19:36:38 GMT
Auto or manual?
Starter turning? Ignition powering up?
Jun 13, 2012 19:53:27 GMT
The head gaskets gone ;D only joking, more information needed!
boo
Jun 13, 2012 19:55:48 GMT
its a manuel , starters not kicking in , everything else is working powering up like it should
rover 25 wont startChasR
@chasr
Club Retro Rides Member 170
Jun 13, 2012 20:00:39 GMT
Do you hear a clicking or anything like that? I know some Rovers need you to de-immobilise the car a la various CAT 1 alarms like Clifford and Cobra before you move off which is done with the fob, but I would rule that out if you drive the car often .
boo
Jun 13, 2012 20:07:34 GMT
don't think its the immobilizer. as it working as it should going to pick it up in a bit with a mechanic from were i work . see if we can shed any more light on it .
boo
Jun 13, 2012 20:29:19 GMT
thanks everyone . sorted now a wire from the solenoid is corroded . try and fix it tomorrow
bl1300
Jun 13, 2012 21:06:03 GMT
That sounds like it should be a nice simple easy fix then.
Current fleet.
boo
Jun 14, 2012 20:53:36 GMT
it was, cleaned the terminal up . put a new connector on the wire All is good now
Jun 14, 2012 21:16:07 GMT
it was, cleaned the terminal up . put a new connector on the wire All is good now I love a happy ending!
