Sinky
Run Baby Run......Please!
Help please I just done 83.3km and used 9.41 litres At the currant exchange rate 1.23 euro to the £ It works out at approx £10.50 to do approx 52 miles So say about 25miles to the gallon A bit on motorway and town driving. Is that about right for a Merc w124 2lt petrol manual do you think thanks
2001 Volvo XC70 wagon
2003 Piaggio X9 Evo
How did you drive it? 'Normal' and steady, or with a heavy foot? For normal driving that sounds like too much. But I'm totaly clueless about the modern W124 M111 engines... Oxygen sensor? A temperature sensor? Loom of doom?
That's 51.76 miles, and 2.06 Gallons = 25.1mpg.
I'm going to guess that most, if not all, of the journeys were short - under 10 miles - as you've only done 50 miles in total, so it's probably not unreasonable. Bear in mind that the 2.0 will be working quite hard on the motorway.
Sinky
Yeah!! spot on short journeys not driven hard and it certainly (2lt) has to work hard on the motorway. m111 pretty gutless really pulling a w124 I don't think it suffers from the loom of doom. Does it?
2003 Piaggio X9 Evo
Brian Damaged
West Midlands
Club RR Member Number: 33
Merc ce 200 manual mpgBrian Damaged
@damaged
Club Retro Rides Member 33
How short are your journeys? if it's mainly town driving, that's probably about right, urban driving will cost you whatever you drive. My wife's 06-plated 1400 Fiesta only does about 28mpg on short journeys.
My W124 is a '94 E200 auto, I do a 36 mile per day commute on a mix of motorway/A-road and it's averaging 36mpg. I've checked and double-checked it and it's 100% accurate. Worst I've had is 34, best 38. On a long journey sitting at 60-65 with the cruise control on it does just over 40mpg. Having said that I do very little town driving with it.
As far as I know it's the six-cylinder models which suffer most from engine bay wiring loom troubles.
Merc ce 200 manual mpgChasR
@chasr
Club Retro Rides Member 170
Some big engined cars do surprise you on MPG.
A sheddy Ovlov 740 2.3i Auto I owned did 35MPG average loaded up on a 40 mile commute, with a more modern injected 2.0 before it doing 30MPG average.
The strange one was the troublesome Mondeo V6 we owned. With a slushmatic 'box and not being particularly careful with nearly pure town driving it used to average 24MPG.
In your case for short journeys I would expect it to be better, but not by alot.
my '95 E220 auto does ok too. worst is around 30, and the best on a motorway run to benzboys hood was 42. i can handle that.
froggy
Air flow meters are prone to go a but senile with age on these , any flat spots or hesitation when driving ?
Sinky
Jun 10, 2012 12:29:54 GMT
Yeah .....sometimes. I never really boot it tho?
2003 Piaggio X9 Evo
Onne
I don't think it's far off the mark, my 300SE does about 18mpg on the daily commute, and 25 on a long run (both on LPG) (22/28 mpg on petrol)
1990 Mercedes W126 300SE 1997 Mercedes W140 S320L
