right I need to clear this up bascially I have re routed my copper brake lines (used kunifer) and it comes under the front chassis rail to meet the union which is in attatched to the inner wing (wheel is no where near the union lines clears it perfectly!!) my question is
when they say no brake lines to touch bodywork they mean the rubber (flexi) lines not the copper lines right??
could i get away using a rubber coated p clip to secure that bit in place which will make sure it has no contact with the bodywork at all? like one of these?- www.ebay.co.uk/itm/Rubber-coated-steel-pipe-clips-pk-5-10mm-2988003-/180396150948?pt=UK_CarsParts_Vehicles_BoatEquipment_Accessories_SM&hash=item2a0072d0a4
and also what can I use to prevent the copper lines rubbing against each other just in case?
looking foward to replies hopefully
