hi there as in the title, I have my BMW E28 520 lux manual for sale
E reg, 1986
no tax
mot till november 11th 2012
5 speed manual
no welding ever done
central locking works too
spax dampers and springs all around
535i front brakes, new discs, pads and shoes about 200 miles ago.
I bought this with the intention of turning it into a bit of a summer pimping drifter but never touched it as my evo took over things lol
its clean for its age, 2.0 6 cylinder so makes the right noise but not that fast. I was going to pop a 3.5 in it and have some fun but never bothered.
its a bit damp inside so I will clean it out and get the windows open etc...
front electric windows work, keep fit rear windows work, electric sunroof and mirrors work too.
just needs a good home
need it gone asap please
£500
07792956314
front numberplate surround has fallen off and is temp cable tied on, just needs re screwing on, battery is flat so il get it on charge, and the tyres are a bit perished from standing but its a cheap clean car that gets attention everywhere it goes
new pics as of just. I've not even washed the car yet and you can see how clean it is
I can't get underneath at the mo as its quite low on my drive but its never been welded and the valance is still ok as is the wheel well, tank and tow point etc...
the only visible body damage is a scrape on the rear corner and its cracked the light
trim needs a good clean but not bad for 26 years old
its also really clean around the doors for its age
as you can see for its age its a nice car. has blue trim, and a tech 1 e30 steering wheel which suits the age of the car. one more problem I found is the brake light switch needs resetting or replacing as its stuck the brake lights on but they go off if you lift the pedal up with your toes lol
cheers
£500
07792956314
E reg, 1986
no tax
5 speed manual
£500
07792956314
cheers
£500
07792956314
