tigran
In rust we trust. Amen.
Club RR Member Number: 142
Triumph TR7 axle.tigran
@tigran
Club Retro Rides Member 142
May 26, 2012 18:14:09 GMT
Hey guys. Need to pick someone's brains.
The Judge is running a TR7 rear axle. I am absolutely fed up with the mentally low gearing of the axle. It sits at around 3500rpm at 65. So i need to seek out a more suitable rear axle. It needs to be a live rear axle, and how strong/weak it is isn't of the greatest of issues for me as i'm going to weld it up anyway.
Any suggestions?
I'm more interested in what's long geared as opposed to anything else.
May 26, 2012 21:57:14 GMT
Which TR7 axle?
There are two (at least).
Early 4 speed 7s used a Dolomite axle. I think manuals were 3.63:1 and autos 3.27:1. It's a weedy axle. 2.0L the limit.
5 speed TR7s used a much beefier unit similar to those used in SD1 Rovers (and Dolly Sprint).
3.9:1 ratio on the manuals as standard. TR8s had 3.08:1 as also used on SD1 3500. 3.45:1 also exists from Sprint and smaller engined SD1s.
Either way you can probably stick with the same basic axle, just swap the ratio?
Nick
tigran
@tigran
May 26, 2012 22:43:50 GMT
Yeah that's what i was pondering, to get a SD1 3500 diff, the lower the better.
Thanks a lot for the help.
tigran
@tigran
May 26, 2012 22:47:48 GMT
Just had a look, christ alive are they thin on the ground!
Rimmer bros stock the CROWNwheel and pinions, 3.45 is £175 (or weirdly you can buy a kit (# ro1168) for £150 which comes with one : the 3.08 is £500
1977 datsun 810 180b estate
tigran
@tigran
May 27, 2012 10:12:01 GMT
Yeah the ones i want are mental money, don't even look at their 2.84 offering, also deffo don't look at the £120 surcharge!
Two words, one begins with F and one begins with T
v8ian
May 27, 2012 12:33:29 GMT
Taller tires??
May 27, 2012 15:35:01 GMT
Rover P6 3500 diffs might have same internals? I know they are 3.08:1......
Nick
