May 20, 2012 14:37:23 GMT
Thanks to others modern disposable living, I now have a surplus of ex-mower briggs and stratton engines ;D, was thinking I could build a dirty water pump pretty easily, but what else could I use them for? Sadly I think it'd be a bit of a curse word to change the output direction so i could build a kart with a couple of them.
rod
May 20, 2012 15:32:23 GMT
Hmmmm...there is a possible way of changing the vert drive to horizontal,by a bevel box off summat (ride on mower?) Ive seen it done,but cant remember what was used.I'm sure I saw it on a obscure website somewhere!
Last Edit: May 20, 2012 15:33:55 GMT by rod
May 20, 2012 15:48:01 GMT
Use an alternator to make a 12v generator. Lorry cooling fan on shaft and use for hovercraft project. Ride on mower gearbox / transaxle will give drive for a buggy.
powered merry go round..
if your looking at a kart i would say that youd be better off either ebaying the ones you have, or taking them to your local mower repair place and selling them there, and buy a decent horizontal shaft mower engine - you may even work out a part ex with the mower guy. This would be a far easier route than bevel boxes etc.
rod
May 21, 2012 10:34:25 GMT
Agreed,but its not in the spirit of making it work.
May 21, 2012 10:47:26 GMT
in which case your back to the powered merry go round!
May 21, 2012 12:09:25 GMT
I've seen two-stroke vertical-shaft engines that have been turned around to sit horizontal. On a two stroke the only thing you need to do is adapt the intake manifold to turn the carburettor around so that it sits the right way up.
In terms of things that you can do with a vertical shaft, as mentioned before, they work well for a hovercraft lift fan.
May 21, 2012 13:36:43 GMT
Worked on a Merry for a while, my carving skills aren't up to doing one justice!
May 21, 2012 17:22:42 GMT
Depending on the engine, two or four strokers should work OK if you flip them to run the shaft horizontal and the head canted down to 45 degrees ish. I did it with great success for my chopper!
Lewis
May 22, 2012 13:03:55 GMT
Is there a particular reason a diff has to run with the shaft horizontal? Just thinking that with a horizontal chain drive from a diff flange, the engine crank can remain vertical.
I am still after a Honda GX25 or GX35. They're dry sump four stroke strimmer motors with a cambelt in the crankcase which can be run at any angle. Supposedly they're super quiet so would make a good camping generator.
May 23, 2012 12:36:46 GMT
Anyone who wants a b and s 12 hp vc motor i have one in my shed think it has the electric start free to a good home collection from nn113yy
Regards
Steve
Ginetta G15 BMW K1100 conversion Sold Mk1 Mx5 on ITB'S Sold TVR Chimaera 400 supercharged MR2 Red Roadster 2ZZ Bee*R 324 Skyline 95 Cherokee Jeep
Wheelspinner, you have a PM. ^^^^
May 24, 2012 12:58:11 GMT
Replied
May 26, 2012 21:14:17 GMT
Thanks for the ideas - so far i've just ended up repairing 4 of the mowers but i've still got decent spare engines! Hard to kill doesn't quite sum it up for those!
Use an alternator to make a 12v generator. If you can couple up an old tumble drier motor or any other big brushless squirrel cage motor it might be possible make a mains generator pretty simply. Instructions over here. Big high voltage DC capacitors can be salvaged from old computer monitors. I have a biscuit tin full of them. I guess the engine would need a governor fitted (mowers usually do though, don't they?) and in good order for it to work reliably as the speed needs to stay constant under load.
Why not bolt a diff to the underside of the engine, then have shafts coming out to the rear wheels? Easy way to make a rwd cart
There's no clutch set up on the mower engines, guess i could use a belt driving a pulley on the diff and engage drive by tightening it. But i think the whole diff set up would be way more weight than these could handle.
in that case.... turbo it! ;D lol A small diff weighs what... 10kg? You weigh what... 70kg? And you're expecting it to pull you around with ease - which it will do Or - take the spider gears from inside an old diff, to make your own 90 degree gearbox
I have a rolling chassis from an ariens sit on it has a 3 speed belt driven box if it is any use to anyone?
Jun 10, 2012 15:44:51 GMT
Yup... but you're nowhere near me
