Onne
May 15, 2012 19:28:55 GMT
Hello all, I've taken bits and bobs of the merc (and the moped) All aluminium bits which are grubby and horrible. What is the best way of cleaning these to a shine? And once shiny, can they be covered in clear coat to protect them? Cheers!
1990 Mercedes W126 300SE 1997 Mercedes W140 S320L
May 15, 2012 19:54:34 GMT
Shove them in the dishwasher! ;-)
Koos
Onne
May 15, 2012 20:11:21 GMT
I've asked her... She said no...
MrSpeedy
East Midlands
www.vintagediesels.co.uk
May 15, 2012 20:45:34 GMT
That's your first mistake right there. You don't ask, you wait till she's gone shopping, or some other stereotypical activity Most water wash degreaser will take care of the oil. A bit of wire wool does wonders afterwards.
Dez
Club RR Member Number: 34
Cleaning cast aluminium Dez
@dez
Club Retro Rides Member 34
May 15, 2012 20:48:55 GMT
electrolysis tank is good at lifting oily dried on grime off engine bits, and that horrible powery white guff of ally bits too.
i actually prefer a non-shiny finish on ally bits, so i tend to sandblast them them then laquer straight away, give a sandcast look to them.
Onne
May 15, 2012 21:06:53 GMT
I'll try that. I'm sure I can find some degreasing agent in the house, and get some wire wool!
Onne
May 15, 2012 21:10:23 GMT
The shiny part is mostly for the sides of the moped engine btw. For the rest I agree with Dez, under the bonnet can just be clean.
May 15, 2012 22:17:19 GMT
For corroded alloy I find the type of oven cleaner that clearly states "not suitable for alluminium" works great :-) You only have to leave it on for short period otherwise it will eat into the good alloy but easy to do several light applications - washing off with water inbetween each
Paul h
Theres a company called Flitz or similar sells an alloy cleaner aimed at slot mag wheels and the like which I haven't tried but is supposed to clean all ali stuff up a treat
mikeymk
'85 Polo Coupe S 1.6 16v
May 18, 2012 10:07:51 GMT
I've asked her... She said no... What? Isn't it your dishwasher too..? She puts burnt greasy pots in it, what's the difference? Oven, dishwasher, i've used both for engines and she had no say in the matter - but for assurance that both would be left suitably clean. And i was being tactful - the alternative was her getting slapped, gagged and tied to the bed ready for once i'd finished with the engine. WTF happened to men. Seriously.
May 18, 2012 10:52:14 GMT
Theres a company called Flitz or similar sells an alloy cleaner aimed at slot mag wheels and the like which I haven't tried but is supposed to clean all ali stuff up a treat Also "WonderWheels" works well, used to use it on motorcycle wheels
