scotchlokmudbitz123
@GUEST
May 15, 2012 17:07:26 GMT
always been old school when it came to wiring ie terminal blocks or insulating tape need to wire in a towing socket and was quoted 60 pound to do the job when I'm sure its easy to do using scotchlok connectors socket is pre wired do they stand the test of time and rugged for everyday abuse?
May 15, 2012 17:20:48 GMT
If you use the right sized scotchlok for the job in a 100% dry situation they are OK.
They get the bad reputation from people using the wrong sized one, or using them in damp engine bays.
They also won't take any abuse (cables getting tugged on at all will usually pull them off)
Last Edit: May 15, 2012 17:23:00 GMT by cobblers
scotchlokmudbitz123
@GUEST
May 15, 2012 17:41:42 GMT
thanks for info abuse i meant usual wear and tear would cable tie to stop any movement
May 15, 2012 17:44:10 GMT
Yeah, so long as the cables are all supported from being tugged or rattling around and you make sure you've got the correct size scotchloks, you'll have no problems. They're a lot more reliable than terminal blocks!
May 15, 2012 17:44:23 GMT
Just as easy to solder & use tape or shrinkwrap, & you won't have any problems with loose connections.
scruff
May 15, 2012 22:05:50 GMT
Please don't use them they are horrible nasty things. Solder and heatshrink or proper crimps and heatshrink if you can. Every time someone uses a scotchlok the god(s) of your choice crush a saveable retro...
1994 Lotus Esprit - Fragile red turbo with pop up lights. 1980 Porsche 924 - Fragile red turbo with pop up lights.
I spy a trend...
May 15, 2012 22:39:22 GMT
Solder and heatshrink, or just decent crimps Skotchlocks are a bodge at the best of times, and useless every other time! and comparing skotchlocks to terminal blocks, or twisting+taping, is like asking whether it's better to build a house from shoes, or chocolate bars..... no matter how you justify it, it's still going to be curse word compared to bricks
scotchlokmudbitz123
@GUEST
original asking cos scotchlocks are supplied with the kit i got for towing electrics
Last Edit: May 16, 2012 8:09:19 GMT by ianboyd
scotchlokmudbitz123
@GUEST
May 16, 2012 14:49:29 GMT
got one used it today connecting wiring on my tow beacon as i said I'm more old school on electrical connections hence asking general overview on scotchloks which i aint never used probably cos don't like change!!!!!!!!!!!!!
May 16, 2012 21:45:53 GMT
4 out of 5 cars i went through recently in the scrappy had scotchlocked towbar wiring. i soldered mine though.
tardis
May 16, 2012 22:43:06 GMT
If you use the butt type crimps get the heatshrink ones then all you need to do is crimp them on and warm them up for a perfect watertight seal, should be available from any good auto electrical supplier. We use them on our vehicles and they are on and off construction sites every day.
Seth
May 16, 2012 22:46:58 GMT
4 out of 5 cars I went through recently in the scrappy had scotchlocked towbar wiring. I soldered mine though. That proves that if you use scotch-loks on your tow bar wiring there's an 80% chance of your car ending up in a scrapyard. Or something.
tardis
May 16, 2012 22:48:40 GMT
This sort of thing.
10mpg
Club RR Member Number: 204
scotchlok10mpg
@10mpg
Club Retro Rides Member 204
Scotchlocks are fine on most towbar installations, provided the wires are in good condition, and the connections cannot move and most importantly are DRY..
99 times out of a hundred it is easier to solder and then heatshrink (which is what i do) then it's permanent and weatherproof but I've seen plenty of cars that have been fine for decades on scotchlocked towbar installs, they gained a bad rep due to misuse usually external and as part of a bodgy repair..
Solder and heatshrink for me,just check the wiring is correct first!!!!
But seriously towbars are a really bad source of electrical gremlins when badly wired so well worth ensuring the in car connections are perfect.
I did my trailer years ago and it's constantly kept in the rain outside yet the plug works perfectly everytime,saves plenty of hassle from the old bill as well.
I'd personally prefer connector blocks over scotchlocks,they really are dreadful and the obvious sign of a botcher to us electrical types.
Copey
May 17, 2012 10:04:19 GMT
solder and heatshrink, scotchlocks are very poor and often give a bad connection they are very unreliable, very very lazy way of doing wiring! if you cant solder use normal connectors and then heatshrink over them, still not a great way of wiring, but better than scotchlocks! hell, twistin 2 wires together and stickin tape on them is probably a better way than scotchlocks!!
May 18, 2012 17:39:11 GMT
4 out of 5 cars I went through recently in the scrappy had scotchlocked towbar wiring. I soldered mine though. That proves that if you use scotch-loks on your tow bar wiring there's an 80% chance of your car ending up in a scrapyard. Or something. ;D
