Has anyone seen or know of anyone running banded steelies with original mercedes wheel trims thinking of doing mine. That style wheel trim, or if anyone is good with the photoshop would you lower it and some banded steelies on plz ;D
VIP
If you put the hubcaps back on, you wouldn't know they were banded, so essentially you're photoshopping something that's hidden?
sry i should have been clearer, i want them banding then ill modify the trim and fit to the inner part so looking standard but with wide/deep dish wheels
tome30
tome30
Dez
Club RR Member Number: 34
they're a b1tch to cut down neatly, cos they're quite thin stainless. youd also need to come up with an alternative method of mouning them too, as they attach with clips in the vents, which youd be cutting off.
the trims are 15 1/4" so was hoping they would fit in a 16" banded wheel with little or no modification then ill tags or a band on the inner part of the wheel to hold them on. Well thats the idea anyway.
Spotted this on a show some years back... Banded, chromed steels with the early style smal hubcaps that go in the center: Quit neat if you ask me Was thinking of going that route with my Tea
What you want is either the 13" steelies found on W110 and W111 Fintail Benz's, or like I have: 14" steelies from an early w108 or a late w113 Pagoda SL. They all feature a separate inner hubcap, and an outer trim ring on the 14" ones. Band to death for instant win!
Spotted this on a show some years back... Banded, chromed steels with the early style smal hubcaps that go in the center: Quit neat if you ask me Was thinking of going that route with my Tea That but lower and ill be happy maybe bigger rim to begin with.
had exactly the same idea for my W115 240D, same colour as yours retrostu... guess I'll be thinking up something else now ;D
1970 Beetle 1600
1973 Rover P6 2000SC
1993 Audi 80 Avant 1.9TDI
1996 Transit SWB pop top camper, 2L Twink
Brian Damaged
West Midlands
Club RR Member Number: 33
This shot..... .....is giving me exceedingly bad thoughts, which I really should banish from my brain. ;D
had exactly the same idea for my W115 240D, same colour as yours retrostu... guess I'll be thinking up something else now ;D nothings set it stone yet, theres a high likelihood of it being left as is. depends on how much it cost to get a mot on it.
This shot..... .....is giving me exceedingly bad thoughts, which I really should banish from my brain. indulge immediately ;D
Jowey
These are 15" Merc steel hubcaps cut down and then mounted using a 13" chrome beauty ring
2000 Mercedes E55 //AMG 1998 Alfa Reomeo GTV 24v 1997 Alfa Romeo Spider 16v 1996 Alfa Romeo Spider 16v 1996 Suzki Swift 1.0 GLS
May 10, 2012 10:02:03 GMT
One crazy german went another way with his hearse. He took old remotec alloys in 8x16 and attached those small caps to the center caps. more pics please ;D
May 10, 2012 23:07:09 GMT
Well I'm going to put this one in here at least. If you've got Google Chrome you can translate the blog... sort of. It's at least partially understandable.
