which one to get I'm on a budget but tbh i got to do my corsair and mk1 tina full lines and I'm tucking them away i want to have a decent tool that will last a long time and produce the goods!
what would you recommend as i have seen the cheap 10-15 quid kits but are they any good?
budget would be around/under £80
help please.
Copey
i used a small hacksaw with my pipes, not the best but didn't have a cutter, the laser one does look better but the bloke is ripping people off with the postage prices
well as long as they are not that bad i suppose theey will do for now how are they with the actual flaring then? do they seal up fine and i will be using kunifer too..
Copey
i guess, all the others are £30+ though, i got mine from AFL for about £20, ebay isnt always cheapest
Copey
well as long as they are not that bad I suppose theey will do for now how are they with the actual flaring then? do they seal up fine and I will be using kunifer too.. never had a problem with any leaks, seems to work great
just make sure it is all square (cut, and flare) and it will seal up fine follow the instructions about how much tube to leave protruding when you make the flare though
will do some hunting then for that 'type' of kit
oh and just to note i would need an imperial kit for a corsair and mk1 cortina right?
I don't think the flaring bit is too sensitive to imperial/metric-ness, its mainly the fittings that make the difference on that front... Take your time and it will work out fine with one of those 'less expensive' kits, otherwise there is quite a jump to the "heavy Duty" kits *scurries off to find a link*
cheers guys well i will go for the less is more approach and get one of the kits as listed above
otherwise there is quite a jump to the "heavy Duty" kits *scurries off to find a link* Indeed. For example, the Sykes-Pickavant 270 series is a really good bit of kit that will last a lifetime (or more) - but it weighs in at nearly £140 for the basic kit which can only do one size: www.ebay.co.uk/itm/330651824485And goes up to £230 for the full set: www.ebay.co.uk/itm/190290312810
scruff
Be sure you make the right flares (single/double) but it's not hard after a bit of practice.
1994 Lotus Esprit - Fragile red turbo with pop up lights. 1980 Porsche 924 - Fragile red turbo with pop up lights.
I spy a trend...
will practice for a while don't worry and yes will be looking at how they are when taken off noting down and re doing them
i use one like this: IMO its less fiddley than the other type and easier to use in situ. Search the bay for sealey AK5063 i got mine for £35 delivered. I've got the other type too and its doesn't get used at all any more.
1977 datsun 810 180b estate
i have looked at those i don't know what to do ive never done this before hence this thread, i don't need to to the lines in the car really as I'm making my own pipes ..
Dez
Club RR Member Number: 34
brake pipe flarer kitsDez
@dez
Club Retro Rides Member 34
ive got the old style sykes pickavant one that looks a bit like a G-clamp, and its beyond awesome. its the only one ive had that shrugs off stainless steel lines no problem, all others ive had/used feel iffy at best, or just break looking at it. a lot even struggle with steel lines tbh. you should be able to pick up the old type sykes one within your budget. they seem to fetch up to 75-80 on ebay, but thats a full kit with half a dozen sets of dies. i got mine for the grand total of erm, about nowt (well, swapped for a little favour/job)
some on ebay now I'm watching will put a wanted ad up on here too see what crops up !
