fha772
Aye up, I'm hoping the Benz W123 owners on here can help me with a little bit of info... I'm having a bit of a problem with my Mercedes W123 280E project, when I bought it, it didn't have any front springs. I've now stripped it out for track use, removed as much weight as possible. I'm thinking of cutting the Spax springs I've got for it, to get it lower, but seeing as it didn't have springs in the first place, I've got no point of reference for how high or low my car is, from standard ride height. So, can any W123 owners out there please measure from your hub centres, to your wheel arch lip, both front and rear and post it here please, along with wether or not you car is already lowered, so I've got some sort of idea of how much I've lowered my car. Any help will bd greatly appreciated... Cheers Frank.
i put 40mm lower springs on my w123 230ce and i cut half a coil off and the is still 10mm gap at the top at the front with 195/60r15s, the rear i just left them with the 40 mm dropped springs it could go lower but a have bad back so don't want it any lower hope that helps you sir
p1RATE
this wont be helpful, but i found this picture today
• 13 BMW 320d
• 92 Pink/Purple Mercedes 190e (Project)
• 97 Rover VI 1.8 (track car)
mylittletony
Club RR Member Number: 84
This was mine: click mebefore (sky high) and after (much lower) cutting 2 and 3 coils from the front springs. Merc springs are crazily strong, take care fitting them! stripping it out won't remove all that much from the front as the engine is 95% of the weight!
fha772
Thanks guys, I'll be fitting the springs next week, and the 17" AMG's, then we'll see how low I can get it before PPC in the Park on May 19th.(Christ!! That deadline is getting too damn close!!)
I know it won't get as low as the sketch in my signature, but we shall see...
This is quite low. Springs: King front and Pedders rear & Bilstein shocks Sunraysias steel wheels 15x10 ET -30 and 15x8 ET -10 & Nankang 175/65 front, 195/55 on the rear edit sump clearance was 30mm.
Click picture for more
fha772
This is quite low. Springs: King front and Pedders rear & Bilstein shocks Sunraysias steel wheels 15x10 ET -30 and 15x8 ET -10 & Nankang 175/65 front, 195/55 on the rear edit sump clearance was 30mm. NOW YOUR TALKING!!! ;D Did the tyres rub much? I'll be running 225 45 17 tyres, I can't run anything smaller than 16" because they need to clear the 560SEC brakes that I've fitted up front.
How do I know? It is not my car
This is mine (on air) The lowest point if the car, the exhaust, is about 1/8 or an inch off the ground and it rolls fine on very flat ground like a smooth motorway but theres almost no steering lock! About 1/4 of a turn either way before the tires start to foul the wings. As for chopping the springs on yours, just keep chopping until your happy with the ride/handling/comfort/looks. Theres no right or wrong amount to lower a car, just right for you.
fha772
Thanks, I think I'm going to fit the springs, and then start cutting half a coil at a time, and see how it goes. I'm going to use this as a track car, so I still need full steering without fouling.
May 10, 2012 22:02:57 GMT
Found another low one: Specs according the Interweb BBS RS 023 16×8 +24 205/45/16 BBS RS 058 16×10 +11 245/35/16 Suspension Air suspension with Continental airbags, oil pressure shock absorbers
ikon31
May 11, 2012 16:44:48 GMT
that silver limo, is AWESOME.... reminds me of my old one and on normal steels, I miss that car soooooo much. My wallet misses it much less i did the standard cut, which was 3 coils up front and 2 up back?? i have 17" x 8s on it, with 195 45 17s no rubbing what so ever,
Last Edit: May 11, 2012 16:48:20 GMT by ikon31
van life is the high life
May 11, 2012 17:48:29 GMT
May 12, 2012 10:12:34 GMT
Based on very rough measurements, I make this one 10.6" from the wheel centre to the arch. Found another low one: Specs according the Interweb BBS RS 023 16×8 +24 205/45/16 BBS RS 058 16×10 +11 245/35/16 Suspension Air suspension with Continental airbags, oil pressure shock absorbers
" East bound and down, loaded up and truckin' "
May 12, 2012 12:43:48 GMT
heres mine, cant remember how many coils i cut off as it was 7 years since i did it. on stock hats with 185/65s, i think on 16 x 8s with 205/55s front and 225/50 rears i couldnt run it with the fronts on 205s as it rubbed the arch going in a straight line. so i put the pentas back on my SEC and refitted the hats as per the first pic.
