FOR SALE IS A 2000 VW POLO 6N2, SELLING AS SPARE REPAIRS AS MOT EXPIRES 21ST JULY AND NEEDS A LITTLE TLC
GOOD POINTS
LOW MILAGE, HAS ONLY COVERED 81000 MILES
ONLY COVERED 3000 MILES SINCE LAST MOT
COMES WITH 4 TSW RIMS THAT I HAVE JUST GAVE A QUICK REFURB
ALL TYRES HAVE REALLY GOOD TREAD
1L ENGINE SO VERY ECONOMICAL
CHEAP TO INSURE AND TAX
HAVE HAD OVER THE PIT AND IS VERY SOLID UNDERNEATH
NO RUST ANYWHERE
FULL V5 IN MY NAME
SHOULD PASS MOT WIITH LITTLE WORK,, MAYBE JUST A NEW BACKBOX
HAS AN IMMOBOLISER IN GLOVE BOX
COMES WITH BRAND NEW VAG SOFTWARE AND CABLE (NOT USED AS IT NEEDS WINDOWS XP)
BAD POINTS
NEEDS A NEW BACK BOX HAS THE CURRENT ONE HAS A 2 INCH HOLE. ABOUT £20
DOES DRIVE NORMAL UNTIL EPC LIGHTS COMES ON WHICH CAUSES IT TO HAVE A IRRATIC IDLE (HUNTING FOR REVS) DUE TO THE ABOVE PROBLEMS, COULD ALSO BE A SENSOR BUT I WOULD THINK IT WAS THE ABOVE, VERY COMMON ON THIS CAR. ONCE ON IT CAN BE RESET BY DISCONNECTING BATTERY FOR 1 SEC
THE PREVIOUS OWNER SPRAYED ALL THE BLACK TRIM AND DOOR HANDLES THE SAME SILVER AS CAR AND THE SANDED THEM BACK TO BLACK AND LOST THE 2 SIDE TRIMS ON THE DOORS WHILST DRIVING. ABOUT £10 BUT I WAS GOING TO REMOVE ALL TRIM AND SMOOTH IT OUT
THINK THE BACK BUMPER HAS BEEN REPLACED AND SPRAYED BADLY AND PAINT HAS COME OF/SCRAPPED OFF ON A REAR CORNER ALTHOUGHT THE PLASTIC HAS NO MARKS
SPEAKER HOLES CUT OUT IN PARCEL SHELF, NO SPEAKERS OR STEREO INCLUDED
GLOVE BOX HADLE BROKEN OFF. £5
PASSENGERS WINDOW WINDER HANDLE HAS BROKEN. ON EBAY £5
IT HAS SAT IN GARAGE FOR 4 MONTHS AND STARTER MOTOR AS STARTED TO SQEAL ON START UP AND NOT ALWAYS START, GOOD NEWS IS ITS A VERY COMMON PROBLEM AND EASY TO FIS AS IT JUT NEED GREASING, INFO CAN BE FOUND ON LINKS BELOW . IT DIDNT DO IT BEFORE PUTTING IN GARAGE AND THEREFORE MIGHT STOP AFTER BEING GIVEN A GOOD USE. ALTERNATIVLY CAN BUY THEM OFF EBAY FOR £20
www.clubpolo.co.uk/forum/lofiversion/index.php/t104661.html
www.sr20forum.com/technical-information-library/97258-how-get-rid-starter-squeal-without-removing-starter.html
I HAVE TRIED TO BE AS HONEST AND THIS COULD BE A GREAT LITTLE CAR WITH A LITTLE TLC REASON FOR SALE IS I HAVE TO MANY CARS REQUIRING WORK AND NOT ENOUGH TIME.
LOCATED JUST OFF JUNCTION 28 M1
I WOULD SWAP/PX THROUGH EBAY FOR ANY OLDER VW WITH LITTLE CASH EITHER WAY, TRY ME WHY?
more photos s1175.photobucket.com/albums/r640/hippey91/polo%206n2/
GOOD POINTS
NO RUST ANYWHERE
FULL V5 IN MY NAME
BAD POINTS
