Plans were for this to go in my Ghia but I have decided to move to London in September so this has to go as I need to save as much money as possible. It is out of an 89' XR2 so is a lean burn with a round top weber. Standard airbox that has a K&N filter inside. When I got it I replace the cambelt, tensioner and water pump, thermostat, plugs and rocker cover gasket. Comes with an exhaust gasket, oil filter and luk RS Turbo clutch as well. It is pretty much ready to go. The guy I bought it off took it out of this XR2 because he zetec'd it and said the engine has around 60k on it, I have no reason to doubt this because when I took the clutch off it was an original motorcraft item.
Looking for £75 collected from Bury St Edmunds, Suffolk.
