right we've been trying to fit electric windows and c-locking to a 95 5door merit, all the gubbins and looms have gone in the doors fine, BUT the loom on the car dosent seem to support it, ie, theres only 2 wires going to the door plugs (speaker wires). has anyone else done any upgrade like this? I know on mk2 cavaliers the loom was a plug in module seperate from the main loom and simply plugged into the fuse box. can anyone tell me if the higher spec astras have a similar set up? as currently the windows and locking wont work!!!! basically do I need a complete loom or is it a plug in bit? assuming I can remove it from any astra with c-locking and electric windows! all help appreciated
2006 Audi A3 2003 Fusion 2 looking for a project....
skinny
Eeeeee!
I've done a leccy rear window conversion on my old Cav Sri. I originally just hunted down door looms and all the other relevant parts as I was told that would be all I needed. So, there I am, with a stripped out rear and all the parts ready and then zoinks! No plugs in my original loom. I was no way going to splice the fugger so I ran to the nearest scrap yard.
£5 later and I had myself a full on floor loom from a CDX! Yayness! Oh, and it was a curse word to install it all again grrr
skinny
AND... trundle over to www.vauxhallownersnetwork.co.uk for more info. They are truly the best Vx club around (and I used to be a hardcore user on there under another SN) ;D
right thats that abandoned then... back to good old winders and pulling up buttons by hand
by another 95 astra with leccy windows, much easier
right its all back to standard manual everything.. on a happier note, my micra door came back from the painters yesterday, so i get to play with fitting all the internal gubbins on that soon
