Apr 21, 2012 17:14:27 GMT
Right, I finally got round to tackling the rear wheel bearings on the Golf today. The N/S was a doddle, everything came off nicely. I've come to the O/S and the two 8mm allen head brake carrier bolts have rounded off, I think they were originally put in by Fred Flintstone. I've tried hammering a socket over them, no good. I've tried hammering a slightly larger hex socket into them, no good. I have no access to a welder and I'm thinking about grinding the heads off and then drilling the thread out once the carrier is off? Access to the top one is a bit cack too.
Anyone got any advice???
Apr 21, 2012 17:20:34 GMT
Have you tried hammering a splined key into them?
Apr 21, 2012 17:20:37 GMT
Personally, I'd be drilling them out and then heli-coiling them.
Apr 21, 2012 17:21:04 GMT
Hammer in a male torx socket of suitable size, or a ..... dunno what they are called, similar to torx but with loads of finer splines. I bought a set to remove head bolts from an old VW golf and they have been dead useful for undoing broken stuff.
tardis
Apr 21, 2012 17:27:02 GMT
^^What dave said, try using a male spline socket, easier to hammer in as they have 12 splines instead of 6 like a torx driver, you should be able to get some cheap ones from the likes of machine mart.
tardis
Apr 21, 2012 17:31:20 GMT
froggy
Apr 21, 2012 17:31:28 GMT
Ribe bits are pretty good but a torx normally works . Get something in the hole to clear any curse word out as it will give you a bit more depth to batter the torx or whatever into it .
Apr 21, 2012 17:53:11 GMT
If you grind or drill off the heads then if you can then remove the caliper I assume there will be enough exposed plain shank to hopefully undo with a stud extractor (or Mole wrench). However I'd do as other suggest and hammer in a 12 sided spline drive key first.
Paul H
Apr 21, 2012 18:17:35 GMT
I feel you pain. I had similar problems with my Golf.
I did it with a combination of methods. On one I used Irwin Bolt removers. On the second, the bolt removers didn't bite for some reason (no shoulders on the bolts mean that it's sometimes not possible to use them) so I welded a nut on and undid it that way (I know you said that you have no access to a welder though).
I'd imagine drilling them out would be an utter nightmare. Possible, if you can get the drill in there, but I think I'd be suicidal by about halfway through the first bolt! ;D
Last Edit: Apr 21, 2012 18:20:03 GMT by BenzBoy
Apr 21, 2012 18:46:12 GMT
Seem to remember I used these, Irwin bolt removers, on my Jetta They've come in handy so many times since they are well worth the money.
I'll get hold of some spline sockets. If that doesn't work, I'll grind the heads off and get the thread out once the carrier is free. WHY did VW decide to use these sort of bolts on a parts of the car which get wet and warm??
It was going so smoothly......I should have known better ;D
If you disconnect the shocks I'd suspect the axle beam can then be lowered (with chassis rails on axle stands) so you can have better access.
paul H
Rounded off carrier hex bolts!ChasR
@chasr
Club Retro Rides Member 170
Another shout for Irwin bolt extractors. However, due to corrosion etc. you may not use the same sized socket on both or at least I found that on some severely corroded bolts.. They really do get you out of tricky situations!
Another shout for Irvin wotsits, they are expensive, but well worth it!!!
povey
Apr 22, 2012 10:55:48 GMT
That happened to me with my mk3 golf, I used easy outs 34 quid on eBay they worked a treat :-)
Apr 22, 2012 11:23:55 GMT
Seem to remember I used these, Irwin bolt removers, on my Jetta They've come in handy so many times since they are well worth the money. This. They are incredibly useful, even if this case they don't work. They're not expensive, £20 for a set of 5.
RobinJI
Apr 22, 2012 11:24:19 GMT
... WHY did VW decide to use these sort of bolts on a parts of the car which get wet and warm??... Because they didn't count of so many mechanics not having a clue how to use an Allen key They're fine if they're not rounded, but like you've found, by the time the cars racked up a few miles and years on the road, it's normally had the caliper bolts and the driveshaft bolts rounded off by someone who doesn't have a clue how to use anything other than a hammer. I'll admit they're not the best quality bolts, and can round on their own, occasionally, but they're fine 99% of the time if no ones got there before you.
Apr 22, 2012 12:08:36 GMT
Have to admit, i have a set of them Irwin removers. Worth there weight in gold, when all else fails. Always worth drowning them in penetrating fluid too. Just my 2 pence worth, good luck.
Hutch
Its a bit of an ANIMAL
Apr 22, 2012 19:17:35 GMT
Bash the bolt round with a proper flat chisel and big hammer. Aim the chisel at the side of the bolt head roughly perpendicular - give it a good few clouts until it makes itself a groove, then drive the bolt round and out.
It'll cost nothing and will almost definitely get the bolt moving.
No need to grind anything, and you should have enough access just by removing the wheel.
Out of the last 3 pairs of golf calipers I removed, 10 of tht bolts were rounded and every one flew out with this method.
Apr 25, 2012 15:46:24 GMT
Have you tried filling the head with screw grab and using the original allen bit? It's designed for rounded off screws but works with bolts and pretty much anything that it's possible to round off. This is the stuff I use. www.schraubendoktor.de/But I have no idea where you can get it from in the UK. I assume there are equivilents. It's a gritty paste that helps the tool bite into the head of the fastener.
