2CV questionDeleted
@Deleted
Actually it's more specifically a 2CV headlight question.
What size are the round headlights on a 2CV? Say I had a pair of bare shells only, what else do I need if I got a pair of halogen or sealed beam headlights to put in. Is there a trim ring to secure the light fitting or clips or what?
stinkwheel
Doctor Of Gonzo Journalism - One of gods own proptypes, never even considered for mass production.
size, dunno. ccan measure later though.
Standard 2CV headlights can be fitted with halogen bulbs with an adaptor ring available in most french supermarkets (or i have a drawing somewhere on how to make some)
watch this space.
1973 Citroen Dyane 6 1980 Citroen Acadiane 1992 Citroen AX 1990 Citroen BX 1997 Citroen XM 1993 Citroen BX 1997 Citroen Xantia 1977 Citroen Ami 8 1996 Ford Escort 1989 Citroen BX 1997 Suzuki RF900 1988 Yamaha TDR250 1979 Honda CB400. 'I need less vehicles'
ScotsDave
Actually it's more specifically a 2CV headlight question. What size are the round headlights on a 2CV? Say I had a pair of bare shells only, what else do I need if I got a pair of halogen or sealed beam headlights to put in. Is there a trim ring to secure the light fitting or clips or what? Light unit is held in with a chrome clip thing on the top of the shell. I can't see any other lamp unit fitting into the shell without a fair bit of maunufacturing. The shell itself is pretty small - you might get a 5.75" unit to fit but the standard 7" unit no way.
2CV questionDeleted
@Deleted
No but a standard 5.75" unit might fit. I'd be looking to get hold of a complete pair off units ready to fit to the Pop. The reason I'm asking is there is a set of empty buckets on eBay but I think it would be false economy if I need to buy an assortment of clips etc. 'Ere they areWhat else do I need? Edit: SVC do a complete 5.75" nest with the lamp, don't know if that might fit. It's about halfway down this page but they ain't cheap. I can't just need the glass headlight unit itself surely?
Last Edit: Nov 1, 2006 18:22:33 GMT by Deleted
Not much help to the actual question, but if you buy headlamps from SVC they might be expensive, but very good. I got mine from there for the Bugrat.
stinkwheel
the 2cv headlight diam is approx 5.6 inches, weird huH!!!
2CV questionDeleted
@Deleted
Mmm, odd size. My logic here is 2CV lights second hand have got to be cheaper than a pair of custom shells but will still light up better than the little 4.5" weiners on the Pop.
