andyborris
Apr 15, 2012 20:00:13 GMT
For Sale Almost new Chris Witor propshaft, less then 500 miles, £80 MK 2 cast iron manifold. Offers Pair of good SU HS4 on manifold. Offers 2000 MK2 engine, good compression, less carbs and manifolds. Offers Gearbox and J type overdrive, works well. Offers P+P is extra on all parts. Sensible offers welcome. Reason for sale here retrorides.proboards.com/index.cgi?board=readersrides&action=display&thread=118875Andy (andyborris(at)yahoo(dot)com) 07528501118
Apr 15, 2012 21:24:02 GMT
Tempting.....
Why did you mod the PI manifolds to take a single tb though?
Koos
andyborris
Apr 16, 2012 16:18:14 GMT
Because you need a Throttle Postion Sensor and all the butterflies inside the manifolds restrict the airflow. And I should have made the ad a bit clearer, the throttle body is mounted on the end of the air box, between the filter and the inlet to the airbox pelunm, Make sense? No? A picture is worth a 1000 words: ;D Have another 1000!
Apr 16, 2012 16:38:53 GMT
Can u show me a pic of the head face of the manifold please?
If it looks vaguely compatible with my project consider it sold.
Apr 16, 2012 16:39:20 GMT
Inlet by the way, it's the fuel injection setup I'm interested in.
andyborris
Apr 16, 2012 18:07:13 GMT
Sorry, no pictures of the actual mounting face, but it's 3 separate manifolds as per Triumph PI. Shows the 3 separate inlet manifolds, PI manifolds converted to take a EFI injector. And a close up of the middle manifold. After sandblasting, but before machining.
Apr 16, 2012 20:49:38 GMT
Interested in the exhaust. Pm coming your way
Rover P6 3500S British beef Moo!!!
