Apr 15, 2012 16:03:19 GMT
is everthiung a straight swap on a mk4 cortina to change from a 4 speed box to a 5 speed box?
same flywheel, clutch starter gearbox mounts clutch and clutch arm etc??
many thanks in advance
estelle rally car nova rally car vauxhall viva camper van mondeo derv vectra on gas
Apr 15, 2012 16:35:00 GMT
It depends if the car is a 1600 or a 2 litre. The 2.0 prop, flywheel, clutch and starter will fit, the 1600 stuff won't. Clutch cable will fit regardless, speedo cable may be too short (sometimes it is, sometimes it isn't...) and you need a cortina auto or capri gearbox crossmember (capri will fit if redrilled). I'm assuming you mean a type 9 5 speed
Apr 15, 2012 16:37:39 GMT
yes mate a type 9 5 speed, its 2 litre pinto at present mated to a 4 speed box,
its actually on starcraft camper which was based on a mk4, ill get it all out and mated up see what is best for the cross memeber,
thanks for the advice
ben
Apr 15, 2012 23:37:06 GMT
straight swap you just need crossmember as said above.
theres more to life than mpg & to much power is just enough.
