The '66 Buick won't turn over on the key.
Either I have tried 2 dud batteries one after the other or the motor is siezed*.
Which do you have your money on?
*obviously there are potentially other faults which can cause this symptom...
jamesp
Apr 12, 2012 12:10:47 GMT
cars not in park ..... lol its the worst thing you can do amout of race cars ive had where i havent fully clicked into park or neautral and sat stranded out on the track like a idiot
tigran
In rust we trust. Amen.
Club RR Member Number: 142
Apr 12, 2012 12:20:20 GMT
I'm going with dud starter, likelyhood of an engine seizing just being sat are so unbelievably unrealistic.
Apr 12, 2012 14:06:22 GMT
Have to say, last time I did this I'd left the car in drive
Apr 12, 2012 16:22:59 GMT
Have to say, last time I did this I'd left the car in drive I've only ever called the AA (or RAC, can't remember) once for an automatic car and their script asked me to double check that. Must happen a lot. But not to Akku. Shurely not...
Apr 12, 2012 16:37:28 GMT
Do you get anything at all?!? Ignition lights?
I'm going to go for an outside bet and say corroded contacts on the ignition switch. Or in drive/the car thinks it's in drive. Shift cables streched/linkage slipped/return spring has streched or fallen off.
Have you tried the old big screwdriver sparky starter motor trick?
Apr 12, 2012 16:57:31 GMT
Ignition lights and dome light dim/go out. Starter "barks" and nothing else happens. Leaving the key in the start position makes a buzzing noise from the solenoid.
Battery shows 13.5v after charging. "Rally" jumpstarter is connected.
No further diagnostics has been possible as I have The Child here today
Last Edit: Apr 12, 2012 17:02:42 GMT by akku
ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
Apr 12, 2012 18:00:35 GMT
I'm throwing bat earth into the hat...
Apr 12, 2012 18:02:31 GMT
I'm hoping its the leads. It'll probably be Sunday before I get chance to look though
crazymonkey
ummm....what was I doing again???
Apr 12, 2012 18:19:23 GMT
I'm throwing bad earth into the hat... yeah thats my bet. battery showing decent voltage but lights dim when trying to start Ive had similar symptoms before with a bad earth.
whoever said dogs were man's best friend....obviously never heard of cable ties
dw1603
Apr 12, 2012 22:35:00 GMT
If it is a bad earth, it will try to find an alternative path. Does the throttle or choke cable get hot whilst cranking?
it doesn't actually crank.
I'm going to start wiggling and poking (my actual skillz at diagnostics are pretty poor) but years ago we bypassed the balast resistor to "cure" another fault and I suspect this is somehow related.
bl1300
What does the battery voltage drop to when the starter barks?
Current fleet.
a bad earth is easy enough to check though, just use a jump lead from the -ve battery terminal to the engine block (assuming its a -ve earth car)
bortaf
Apr 13, 2012 12:38:13 GMT
I'm going to plump for alien probing, go get hypnotised by a clown immediatly If the lights are dimming i'd say the starter is using power and lots of it something it wouldn't do if the earth lead were off ?, seized starter (full of water) maybe (obv if the aliens havn't been snapping the rubber glove nearby lately
R.I.P photobucket
Apr 13, 2012 14:22:27 GMT
Both the starter and the wiring have previous form.
Apr 13, 2012 14:32:37 GMT
quickest way, is have someone holding the key on the start position, while you belt the starter body with a breaker bar !! it usually coughs at least this way!
Apr 15, 2012 12:59:01 GMT
its not been turning because its hydrolocked.
took the plugs out and one pot leaked about a half pint of rusty water.
Apr 15, 2012 14:25:28 GMT
Manure......... (hoping the swesr filter doesn't find word n°4...) That sucks big time.
Apr 15, 2012 14:42:23 GMT
Form the symptoms it sounds to me like the 'malevolent water bull spirit'
