hi all.
my header tank is currently here:
i recently got an ally tank and positioned it in the far left corner, just in front of the fusebox - where the small black box is. the pipe that connects to it was lenghtened and runs through the firewall/bulkhead to the tanks new position.
i now would like to move it to the far right corner - where the corner of the battery is just visible. my plan is to run the pipe from the existing spot, through the firewall/bulkhead, accross the bottom of the windscreen to the new position.
so my question is: does moving the header tank further away from the orignal location (and lengthening the appropriate pipes to suit) have any impact on the cooling system? assuming the (new) position of the header tank is the highest point for bleeding - will it be business as usual?
also - this:
if i had one of these, could I fit it to the top hose and block the pipe currently running to the header tank, and not have a header tank all together? or would that not work?
any help appreciated!
thanks.
also - this:
thanks.
