ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
Ok, I am SOOOO feckin close to my car starting right now. I had a very good indication of spark, but no fuel. I cant suss out my fuel pump... First off, it doesnt seem to match any of the replacement pumps I can see out there. Is it stock? Secondly, it wont pump fuel. Have I got the lines on back to front? At present my fuel in is going to the 90 degree port on the rear side of the pump, and the fuel out to the carb is at the front of the pump. Is this right? Lastly, is it worth considering going to electric? I have a holley pressure regulator before teh carb which may hold up if I fire an electric pump on and do away with this tight fitting nonsense. Would this be worthwhile?
When you checked for no fuel, did you check it at the pump itself or after the regulator?
Going electric can make life easier, but I would be tempted to switch the hoses around (I guess there are no arrows on the pump to show how the fuel flows?).
ToolsnTrack
Homebrew Raconteur
Nah, no arrows. Never been happy with the 90 degree attachments proximity to the engine mount.
My check was symphonic fuel up to the pump, then attach. Then remove output hose from regulator, direct to cup and crank. No fuel, nor pressure when covered with finger.
Dez
Club RR Member Number: 34
I'm not 100% sure if its SBCs I'm thinking of, it might be something else, but i think there may be two types/lengths/shapes of fuel pump pump arm. possible incompatability issue?
ive never had an issue with SBC pumps, always seem pretty reliable, indeed ive replaced a couple of duff electric ones with the stock pumps in the past. only other thing it can really be is the diaphragm.
ToolsnTrack
Homebrew Raconteur
It's not been replaced or changed Dez, it's still the original setup. Will try switching hoses again to see if that's the problem, then the pump is coming off...
ToolsnTrack
Homebrew Raconteur
Apr 10, 2012 18:14:53 GMT
So today i had another crack at it. Switched hoses: No difference. Spat the dummy and ripped the pump off completely and bench tested it. With a spanner over the arm for leverage it does pump petrol! So now i have established the right ends, i reattached the hoses, and pumped it up by hand. Fuel to the filter!!!
So the pump is fine, i re-bolt it up and crank over.... nothing. Sobofabitch!!
Pulled it off AGAIN and cracked it with the pump off, whilst holding the pump pushrod in with a screwdriver... seems like its not moving. So does this diagnosis make sense?
Pushrod for the cam to pump arm has siezed in place, but in the fully depressed position? Surely the engine would lock if it was siezed in the neutral off cam position?
Dez
Apr 10, 2012 18:52:47 GMT
if youve had the pump off its more likey its dropped out of position. you kind of have to hold em up whilst you guide the pump in for em to locate properly on the pump. they can be fiddly to get back in right. there some trick about replacing one of the bolts in the block with a longer one to hold it up in position, but ive always managed to do it without.
ToolsnTrack
Homebrew Raconteur
Apr 10, 2012 19:19:37 GMT
That still doesnt explain why the pushrod wasnt moving when i cranked the engine though dez... it was solid....
burns
Apr 11, 2012 12:48:43 GMT
Is there such thing as cam with no lobe for the fuel pump? You replaced the cam recently didn't you?
ToolsnTrack
Homebrew Raconteur
Apr 11, 2012 17:53:13 GMT
Well remembered burns. I did that, but there is a lobe there. I have infact found the problem...
Pics uploading....
ToolsnTrack
Homebrew Raconteur
Apr 11, 2012 19:27:19 GMT
So heres what i found. Pulled the pump off to check the pushrod. Solid as before. Got a torch in there and observed this! curse word pic but this is the view up into the pushrod chamber. See that to the right? That is this: Feckin earth strap bolt! It went right through the block, out the other side, and nipped the pushrod! Must eb a design feature to alloow the rod to be locked before fitting the pump. Clever, if a touch frustrating. Heres the fix: bolt out.... ...washer applied. Fuel pumping a treat now. Thanks to all for the replies, much appreciated!
bortaf
Apr 11, 2012 20:02:13 GMT
Good fooking lord ! i would laugh but thats exactly the sort of thing that happens to me all the time, glad you found it at least ;D
R.I.P photobucket
Dez
Apr 11, 2012 20:17:44 GMT
theres some trick about replacing one of the bolts in the block with a longer one to hold it up in position......... that bolt, does exactly as i described above glad you found it though, its always the simplest problems cause the most headscratching!
ToolsnTrack
Homebrew Raconteur
Apr 11, 2012 21:38:52 GMT
Now we both know Dez... That's the trick!
