Meet the Low, Loud and Lairy: Rotango.
A Bright orange, bagged, cleaned, Mk2 Ford Cortina
with a full rotary conversion.
Originally seen here:
www.iheartstance.com/2011/03/nzpc-hardpark-wellington.html
Following some google-fu, I believe this car to have been built somewhere 'down under'
Most of the info I have dragged and deciphered from the builders Bebo page.
www.bebo.com/Profile.jsp?MemberId=3889876246
Full Rotary conversion.
spec includes:
A fully polished and shaved 12a Monster Bridgeport engine
Gilmour pulleys and 10lb flywheel
48 IDA
Holley Blue Fuel Pump
3inch Straight Exuast
S1 RX7 Gearbox with Exedy clutch
Hilux LSD Differential ,
Radiator with twin electric fans
Stainless Fuel Tank
Disc brakes all around
Chromed and Custom 4-link rear suspension
Laser cut camber casters
Air suspension
Heavily modified shell: Chassis notched, Shaved engine bay, new tunnel, new firewall, new floor
Custom Tube Grille
With White walls and original chrome caps:
and again with 17” Lenso RS5’s (slightly weaker look for me but each to there own.)
Not a very good angle but here it is sat on Polished Modular wheels
Excluding some help from an engineer to do the custom suspension
All fabrication,
panel beating,
shaving and preparation for paint;
right up to rolling the car into the spray booth
was done by the builder
at home
in his garage
which I find very inspiring ;D
Here is the money shot;
Of it sat on the 14” Polished modular wheels (A strong look i hope you agree)
spec includes:
48 IDA
Stainless Fuel Tank
Air suspension
Custom Tube Grille
All fabrication,
panel beating,
at home
in his garage
