Mar 21, 2012 11:33:27 GMT
I need a pair of "headlights" for a project. I'll bosh up a thread when I have 5 minutes. Basically I need a pair of clear white lights about 2.75" across to act as headlights. Can anyone think of a source? Just to complicate matters my electrics are 24V.
Cheers dears I'm all ears
Mar 21, 2012 11:47:13 GMT
Motorcycle custom shop, I'm sure you can get some with clear lens in about that size.
EDIT not sure about 24v bulb availability though...
Last Edit: Mar 21, 2012 11:48:03 GMT by dodgerover
berendd
Mar 21, 2012 12:07:54 GMT
2.75 ? hom much is that in centimeters? isn't that a bit small?
regulars are more like 5.75?
markbognor
Club RR Member Number: 56
Mar 21, 2012 12:10:02 GMT
Kiddies ride on toy?
markbognor
Mar 21, 2012 12:12:51 GMT
Mar 21, 2012 12:15:04 GMT
If you can't get 24 volt bulbs, it's not a problem, just wire the two 12v bulbs in series. You'll lose them both if one bulb goes, though.
berendd
Mar 21, 2012 12:18:57 GMT
Last Edit: Mar 21, 2012 12:21:27 GMT by berendd
RobinJI
Mar 21, 2012 12:31:40 GMT
There's plenty of projector lamps about on ebay, most are under 70mm, but could always sit behind a clear lens from anything else, or just a disc of perspex. I was looking the other night because I'll be needing something <55mm diameter for my mini.
When you say "headlight" though, does it actually have to work properly as a headlight, or is it just to look like one for show?
Last Edit: Mar 21, 2012 12:39:14 GMT by RobinJI
Mar 21, 2012 13:18:28 GMT
it has to illuminate. Thats all. Not pass an MOT! Those ones at 70mm would work but over £100 the pair? Ouch!
I'd thought about motorbike lights... Some bikes have 2 round lights don't they...
berendd
Mar 21, 2012 13:27:13 GMT
look for streetfighter lamps on ebay, there's loads of small round ones
MiataMark
Club RR Member Number: 29
Mar 21, 2012 13:32:57 GMT
Mar 21, 2012 13:47:56 GMT
Last Edit: Mar 21, 2012 13:48:59 GMT by cobblers
Mar 21, 2012 14:10:03 GMT
Do they need to fit into a round hole of that size? If there's an existing light in place, tiny LED projectors could maybe be built in. I use amber versions of these as signals on a bike, very bright but they're much smaller. These are more expensive than others but they're much better made. Cheapos would be fine if they're hidden. www.ebay.co.uk/itm/180846351485Not sure how they're react to 24v but it's nothing a resistor pack couldn't deal with. I only mention it because I've got a half-assed idea/project to hide white ones in a 60s headlight for use on the same bike. The original headlight is awful and has bad wiring. This seems like a good way to get the right look on the bike but not have to accept awful lights.
markbognor
Mar 21, 2012 15:46:30 GMT
Mar 21, 2012 16:55:48 GMT
excellent suggestion
Mar 21, 2012 17:02:18 GMT
Lucas side lights? 3" in diameter: www.ebay.co.uk/itm/200718233725Should be able to pick up some used ones for a lot less. Not very headlight shaped though - more pointy than curved.
kevfromwales
the conrod's REALLY out the block now!
Mar 21, 2012 17:58:37 GMT
what about those 100e round rear lamps? - I know they are pointy, but you can get flat clear lenses for them
if these are for what I think they are for - then yay!
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
Mar 21, 2012 20:32:10 GMT
yeah, mis-measurement or miscommunication. They be 4". I have some spot lights off a mod scooter in my sights subject to eBay... job done.
