Mar 20, 2012 11:04:24 GMT
I've got the above shocks on my Hijet. From what I can see the easiest way to lower it is to remove the spring seating and weld on some threads and get some Shorter Springs. I also have enough space below the unit to move the hub mount up abit to give me some more travel once lowered. First off is this a sensible idea? Secondly I'm guessing you shouldn't grind and weld with the oil in place?? From quick inspection of the top I can't see how you dismantle the shock, anyone have any experience of this? Ta
1970 Porsche 911E 2002 Porsche Boxster S 2002 Peugeot Partner 1.9sdi
Mar 20, 2012 15:08:18 GMT
Mar 20, 2012 15:54:25 GMT
Yeah, cheers I have and in the long run I'd like to get some proper ones made up. Just want to get the front down on a shoestring for the time being.
Mar 20, 2012 16:49:21 GMT
Well, in that case:
Mar 20, 2012 19:55:43 GMT
I knew what that was without even looking. I've already cut the springs but want to go a bit lower.
