aij29
Hi Guys I`ve a little project in mind,I want to make an arch roller,(want to fit 7j rims to my fiat) But the main thing i havent got is delrin rod, I need a piece of white 80 dia about 100mm long, Has anyone got any or use any at work? I will pay postage and a little bit for your time, Cheers Adrian
Never used delrin rod before, so not sure how hard it is. I have some nylon 66 that I might have in a similar diameter.
slater
Club RR Member Number: 78
80mm delrin rod neededslater
@slater
Club Retro Rides Member 78
Oct 22, 2006 16:06:56 GMT
Thats a coincidance, ive been making myself an arch roller at work this week!
I assume you are using the delrin for the roller? sounds huge, mines only 50x50mm and i made it from ally.
Ebay is the place to fond stuff like that tho.
aij29
Oct 22, 2006 17:08:14 GMT
Never used delrin rod before, so not sure how hard it is. I have some nylon 66 that I might have in a similar diameter. Hi Would that be pretty resistant to heat? If so how much would you want for it? I`m after that diameter so i can run roller bearings in it Cheers Adrian P.s Any piccies of the one you made?
slater
@slater
Oct 22, 2006 17:36:43 GMT
No pics yet I'm afrade but it looks pretty much the same as this one from frost www.frost.co.uk/item_Detail.asp?productID=9108&frostProductName=Wheel%20Arch%20RollerMy version is scaled down slightly to do the arches on my small cars as the frost one only goes down to a 14" radius and I'm running 12" wheels! (god knows what cars have 28" rims?? i guess your supposed to use it with the suspension un-compressed but thats far from ideal imo) I'm running 37x12x12 bearings in my roller Will get some pics when its done
