I am selling my Prelude as I fancy a change.
Basic spec:
There are some negative points:
The bodywork is as you would expect. Very light surface rust around rear arches. Hasn't yet broken through the paint but it is there. The paint is faded and could do with machine polishing. One rear cluster dulled due to water ingress. Slight coolant leak from radiator (I top up weekly) Aircon needs gassing. VTEC does not engage when at running temperatur, ie, does engage when temp needle is just below. Hope this makes sense.
Generally the car is presentable and makes a nice comfy daily drive. Despite the mileage it does drive very very well! I will attempt to get the VTEC issue sorted before it is sold.
I would like £500 ono.
Thanks for reading.
Basic spec:
Thanks for reading.
