gruss
Mar 17, 2012 22:37:30 GMT
I've got a gizmo boost controller and would like to rig up a boost memory/ over boost momentary switch on my steering wheel. I've got one of these for my Momo steering wheel.. www.ebay.co.uk/itm/270914755628?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_1309wt_938I didn't really check my steering wheel setup but for some reason thought the horn wiring went through the center of the coloumn... It doesn't, it works though a spring loaded contact. My next thought was to get my hands on a airbag squib and use the existing pass through wires but it's not that straight forward finding one etc.. I remember watching rallying and they use a coiled wire to attach to various switches on their steering wheels.. I came across this.. ls1tech.com/forums/nitrous-oxide/705545-nitrous-switch-steering-wheel.htmlWon't the wire just wrap around the steering coloumn? I can't really picture this unless I experiment with an old phone coiled cable.. What do you guys reckon..? I can take pictures of my steering 'area' if that helps..
Daihatsu Mira TR-XX Suzuki Alto Works
Depending on the car it could get caught/jam in the gap between the wheel and the steering wheel cowling.
On rally cars I doubt they had the plastic cowling, so not going to snag.
I wouldnt have a problem using coiled wire, but I'd make sure it was long enough not to put resistance on the wheel at full lock, and not floppy enough to get in the way when loose.
gruss
Last Edit: Mar 18, 2012 10:17:07 GMT by gruss
gruss
Mar 19, 2012 17:16:40 GMT
Can I connect my 2 switch wires to a gutted remote board?
Mar 19, 2012 18:09:57 GMT
Apologies if I have misunderstood/teaching granny to suck eggs etc...
The board on the left of the picture in the last eBay ad you posted is not in the remote, it is what the remote talks to. Mount that somewhere near your wheel, luckily I runs on 12v.
The board has two relays, I'd guess two 'change over' types. If the circuit is set up a certain way, the relay contacts (like a switch) will close when you push the remote button. In effect you are pressing the button on the remote, but switching electrically on the board.
The two wires from your boos controller to the switch (at a guess, do you have any more info on the controller?) will need to be connected to a relay common and a 'normally open' contact. I'll check that ad again and see if I can get some more info. HTH
I've got Rovers.
gruss
Mar 19, 2012 18:20:44 GMT
Thanks www.gizzmoelectronics.com/pdf/MS-IBC%20Instruction%20PDF%20Ver1.01.pdfPage 15 is the wiring diagram showing the switch. I realised from the second eBay link that there is a transponder (the fob)and a receiver. I imagine it will be set up with one button opening the garage door and the other closing? If this will work for what I want it will be ideal!
Mar 19, 2012 18:33:00 GMT
Last Edit: Mar 19, 2012 18:41:14 GMT by SamR380
I've got Rovers.
gruss
Mar 19, 2012 19:03:06 GMT
I've had a read but it's a bit beyond me
Mar 19, 2012 20:29:16 GMT
Don't worry about most of it, it isn't relevant at all. This is what the inside of his remote looked like, the one on ebay will look something like it. Turn the circuit board over and you can see where the little switches are soldered, he has soldered on a couple of wires for a switch, just like you are wanting to. He has done both switches, you'd only need one. As you can see, it's all pretty small stuff and a bit fiddly to solder - but entirely doable. That's the wheel end sorted, this is for the car end. Your blue and red wires from the boost controller will need to be connected to the control box from the remote system. So you have this board, with a row of screw clamp terminals on one side... Underneath, connection details are written on the circuit board. Notice at the top, you have NC1, COM1 and NO1. NC means Normally Closed, ie when the relay is off, the contact is CLOSED. NO means normally open, ie when the relay is off, the contact is OPEN. COM1 is the common supply to the relay, you put the live wire here. When the relay is off, the COMMON is connected to the NC contact. When the relay is on, COMMON is connected to the NO contact. When you press the button on your remote control, it turns on the relay. You may have worked it out by now, but you need to wire your RED to COMMON and BLUE to NO. It would work with the wires the other way round, but it is good practice to put the voltage source on the COMMON pin. If you decide to go for it, let me know and I'll help/do drawing etc.
I've got Rovers.
gruss
Mar 19, 2012 20:43:51 GMT
Sam that's fantastic! I've been looking at the fast and furious 'style' flip top nitrous gear levers but you've made it sound quite simple. I'll buy the second ebayed link and will give you a shout when it arrives. Should be fun! Russ
Mar 19, 2012 20:54:24 GMT
Great, send me a PM when you want to start, I might miss it on here. Discuss it on here though, in the unlikely event it is useful to someone in the future!
Where abouts in S Yorks are you out of interest? I'm in Mansfield, Notts - but visit Sheffield and Rotherham a couple of times a week.
I've got Rovers.
gruss
Mar 19, 2012 21:08:22 GMT
No worries!
I live at bramley junction 1 m18 pal. I'll be going to Nottingham tomorrow for a 2 day course with work so will be passing by you.
gruss
Mar 28, 2012 19:59:13 GMT
Ok minor update on this... Had a small parcel come today! Hopefully will have a closer look at the weekend! ;D
Mar 31, 2012 15:06:35 GMT
I would have used the horn push and horn wires to operate the switch and put the horn switch elsewhere if you were desperate to put it on the wheel. Be fine the way you want to though,take some pics when it's all done.
Mar 31, 2012 15:20:40 GMT
Some excellent google translate on the instructions
I've got Rovers.
gruss
Apr 19, 2012 17:19:20 GMT
This is the board inside the key fob.
Apr 19, 2012 22:07:31 GMT
Ok, that looks usable. Do you have a multimeter by any chance? Just need to check which way the buttons work. I'd guess they're normally open, ie the switch is off until you press it.
Does it look like you'll be able to mount the device around the wheel somewhere?
I've got Rovers.
gruss
Apr 21, 2012 18:56:52 GMT
Yeah I've got one, shall I check both buttons? I'll get onto this next week. The plan is to mount this inside the steering wheel boss behind the horn contact. It's a Momo steering wheel.
Cheers sam
Apr 21, 2012 19:23:43 GMT
Cool, you'll only need one... I guess they'll be the same but it wouldn't hurt to make sure.
I've got Rovers.
