bstardchild
Club RR Member Number: 71
Good to see more pictures an hope the shell is ok after blasting. Keep going with it. Will be worth the wait when its done I'm sure. Spent a little time on it today measuring up for the movable frame/dolly it's going to sit on when it's blasted and primed (mainly so I can move it around and in and out of the garage to turn it around to work on it - must stop myself from getting too far ahead ). Anyway I also had a result in another aspect that was likely to give me issues when/if it's finished and I get to register it in the UK - In hindsight I'm not sure I've fully covered it on here before but I know I've touched on it so apologies if I'm repeating info from earlier in the thread. In Ireland it was registered as 99 GZJ from new and it stayed on that reg during the ownership of Frank O'Rourke as well as Austin McHale - when it left Ireland that registration number was frozen (I'll not go into how it ended up wearing a "B" plate in some of the pictures or why but we all know that it would "ring" some bells) Anyway I managed to get a copy of the Irish reg document from the Southern Ireland equivilent of the DVLA confirming it was registered when new in 79. This also gave me the chassis number something that I couldn't find on the car and from there I used some contacts I have to find out the build records from Opel in Germany and the original colour that Roddy thought was silver was actually a light blue and that tied up perfectly with the original build records Colour can be seen under the peeling paint in this shot I'd had some conversations with DVLA as I want to register it on an age related 79 reg and not contine with the slightly iffy ID it appeared to have - I couldn't get a definative answer out of DVLA - some people I spoke to said without a chassis number to definatively ID the car it would be allocated a Q plate and others at DVLA gave me some hope that the documentation I have gathered would be enough to gain the car a suitable age related plate eben though I didn't have a chassis number. Well today I managed to find the chassis number under a lot of rust and peeling paint and although it's now very faint it is readable (just) and the best news was it ties up so I'll cover it for the blasting process somehow to ensure it's not further damaged or lost
Thats great news!!
WELL DONE FOR PERSEVERING WITH IT!! ;D
tigran
In rust we trust. Amen.
Club RR Member Number: 142
Absolutely fantastic to see some progress getting underway with this! Look forward to the next chapter of this.
great news
theres more to life than mpg & to much power is just enough.
skinnylew
Club RR Member Number: 11
wow just made my self late for work reading through this!! What an interesting story!! Look forward to monitoring its progress over the years ;D
MK2VR6
Mk2 Golf GTi 90 Spec
Wow, what a fantastic read! I've got a million and one things to do, but this was a fantastic way to spend a fast-skim 30 minutes of it! Bookmarked.
bigrod
Good to see you getting on with it Ian! I honestly didn't realise it was such a mess. I thought it was very solid, (albeit a bit toasted.) Love the 'liquid' engineering!!
Last Edit: Dec 5, 2011 11:16:32 GMT by bigrod
If I have to explain, you won't understand. Maximum signature image height = 80 pixels
rob0r
East of England
Club RR Member Number: 104
As normal, a great read Ian. I really hope the news is good after blasting!
E30 320i 3.5 - E23 730 - E3 3.0si - E21 316 M42 - E32 750i ETC
nice to see this car found us irish rally fans always wondered what happened it keep up the good work
bstardchild
Good to see you getting on with it Ian! Yeah - my intentions were to have gotten on with it a long time ago Life sometimes gets in the way. I honestly didn't realise it was such a mess. I thought it was very solid, (albeit a bit toasted.) I still think it is very solid (pending final verdict after blasting) - the problem area was the front end which as a result of having lost the most paint has suffered more than anywhere else - this really highlighted the fact that parts of the GSE front had been badly attached - I don't think this was work carried out in Ireland and there were a few clues that helped me here - the slam panel had chassis tags and trim codes related to a 85 GSE (without applying for another log book I reckon BXXX WES chassis number and tags were used so that sort of fits in with "work" carried out this side of the irish sea) - it wasn't done well at all, more ARC weld rather than MIG and no where near the std of welding work carried out elsewhere on the car The back end was probably already rotten under the paint due to the amount of foam packed round the tank as well as laying it on a bed of carpet!! Love the 'liquid' engineering!! Made me chuckle too when I realised what it was from. I'd love to leave it like that ;D but to do that I'd have to remove it and I don't think that would work out very well - have to see whats left from the blasting stage as it doesn't need blasting there.
bstardchild
nice to see this car found us irish rally fans always wondered what happened it keep up the good work I'm very glad for the help of a lot of Irish Rally fans provided to me in 2007 and 2008 - it was instrumental in putting the pieces of the jigsaw together when we had no idea where the car orginated from, when I'm in a position to properly move forward (ie the shell looks better no worse) my intention is to go back to the information requested threads I started on some of the Irish rally forums and give a little update.
bstardchild
Thats great news!! WELL DONE FOR PERSEVERING WITH IT!! ;D Hi G - Well I didn’t have a lot of choice it got bumped up the list but in a way I’m glad it did Absolutely fantastic to see some progress getting underway with this! Look forward to the next chapter of this. Hopefully not so long as the last chapter Tig – and thanks for your help many years ago in dragging it’s sorry father ted round the country Made my day it did wow just made my self late for work reading through this!! What an interesting story!! Look forward to monitoring its progress over the years ;D I do hope it’s not years – I’d like to get it finished by Aug 2012 so I don't have to turn up at the biggest retro event of the year in the daily.... Wow, what a fantastic read! I've got a million and one things to do, but this was a fantastic way to spend a fast-skim 30 minutes of it! Bookmarked. Thanks – the good reading bit is mostly down to Roddy As normal, a great read Ian. I really hope the news is good after blasting! I do too – I really do.
Good to see progress on this. I didn't realise you got it so long ago. Sterling work so far, a lot of people would have given up on the shell long ago.
bigrod
Yeah - my intentions were to have gotten on with it a long time ago Life sometimes gets in the way. I hear ya! I have that T-shirt. I hadn't realised so much time had lapsed though!!
bstardchild
Good to see progress on this. I didn't realise you got it so long ago. Sterling work so far, a lot of people would have given up on the shell long ago. I'm hopeful that it moves on to stage 2. I've been mucking about with big opel/vauxhalls for years but I've never done a sympathetic restoration (if I can be allowed to call it that) always modify/improve/repair from something that is mostly a regular used car. With this project I'll be starting with a shell and building up from that, my only concern is I have a limited budget (as we all do) and whilst I don't want to cut corners I might have to be realistic in my expectations for the finished article - we'll see I guess ;D Yeah - my intentions were to have gotten on with it a long time ago Life sometimes gets in the way. I hear ya! I have that T-shirt. I hadn't realised so much time had lapsed though!! And doesn't it fly..... Got the Commodore project and the Lotus to finish in the Q after this one - I'll be doing them both when I'm retired unless I get a move on.
bstardchild
Jan 15, 2012 21:34:02 GMT
Just making a Steel cradle to supoport the frame so I can get it back from the blasters so they are waiting on me - should finish the frame this week Meantime a recent new picture surfaced that I'd like to share Made me chuckle ;D
VWPowered
No-Rice - Est 2002
Jan 15, 2012 21:54:38 GMT
brilliant save sir, top marks
81 Bedford CF 2.3D Cavalier Coachman Stratus 86 Volkswagen Polo Mk2 1.6 8v 87 Austin Montego 1.6HL 'Daily' 91 Rover Montego 2.0TD Countryman Estate 93 Rover Montego 2.0LXi Estate
MantaA16V
I can build your dream car
i saw it at the blasters recently and thought i recognised it, looking forward to following this when you get it back.
www.suffolkcountymantas.co.uk 07720 288928 Now on twitter suffolk_mantas CUSTOM BUILDS, ENGINE SWAPS, PAINT. BRAKES. ONE OFF CUSTOM INTERIORS. WHEELS AND TYRES. Max signature image height = 80px
bstardchild
Jan 16, 2012 11:01:02 GMT
I saw it at the blasters recently and thought I recognised it, looking forward to following this when you get it back. Hopefully not to much longer before it's home and I can start work in a more positive direction - ie building up not stripping down Meantime I'm trying to get the other Monza prepped ready for an "all Opel Track day" in France (February 25th) so that's currently all weld, grind, add less weight and modify/improve the brakes now that I've removed the ABS system in order to save more weight (must update that thread when I get some pictures of things that are finished)
nofrills
my wings are made of Steeeeeeeel!!!
Jan 16, 2012 16:27:56 GMT
Wow this is so cool, look forward to reading more in the future, bookmarked,
