Oct 19, 2006 16:17:37 GMT
Just won these of mywifewillkillmebay ebay for a bargain price of £46 ;D Another thing ticked off the list for the KR conversion. All I need now is: Manifold / downpipe Servo and a Gearbox EDIT: I'm a tit wally for not linking a pic!
Last Edit: Oct 19, 2006 19:15:26 GMT by iRocco
Oct 19, 2006 16:23:27 GMT
What's this now? I've missed a few links in the chain.
Sounds ace tho, regardless ;D
I'm guessing this is going towards making the mighty Rocco faster ;D
Oct 19, 2006 16:29:33 GMT
I've just been informed that I'll also need either Audi or Scirocco 16v carriers...oh well!
Only one link in the chain Lewis - I bought a 1.8 KR 16v engine from a MKII 16v Golf that I'm currently re-building to then put in the Rocco (hopefully)
Mr K
Oct 19, 2006 17:46:54 GMT
what have you won? theres no picture or anything to give the game away?
filmidget
East Midlands
Mostly Lurking
I am also still collecting bits for my 16v Scirocco conversion, hoping to start sometime in the near year... Biggest bargain so far was a 2 litre 16v Audi for free
'79 MG Midget 1500 - Still patiently awaiting attention '02 Vauxhall Astra 1.8 Elegance(!) - Better than you might think '03 Mazda MX5 - All new and shiny looking (thanks to Antony at Rust Republic) '09 Renault Clio - Needs to go.
Oct 20, 2006 10:00:16 GMT
It might be a bit late to make it worthwhile but would it not work out cheaper buying a rough 16V golf to get the parts off, or are not all parts interchangeable
Oct 20, 2006 10:17:13 GMT
It might be a bit late to make it worthwhile but would it not work out cheaper buying a rough 16V golf to get the parts off, or are not all parts interchangeable Not really - the only parts you can use from a 16v Golf is the Engine, Gearbox, fuel system (inc pumps . metering head etc), brake servo and the discs and calipers. You can't use the downpipe (although you can modify it) because it's the wrong shape. I've only spent £97 on the engine, fuel system, discs and calipers - so unless the gearbox (it doesn't need to be from a 16v - I can use a 1.8 8v box from a Golf / Scirocco) and servo is going to cost me £300 - £400 i'm quids in.
Stu
Oct 20, 2006 12:44:39 GMT
If you buy a secondhand 'box my tip is to change a few seals on it or it might leak oil onto the clutch making it slip and have to come apart again, which is annoying... ask me how I know...? Things to change - push rod seal and brass bush and input shaft seal, a couple of quid for the lot from GSF. Also may be worth changing, or at least checking, the seals on the driveshaft flanges or they'll leak oil into your inner CV's and also onto your driveway... again, I know... This site is fantastic for transmission info www.brokevw.com/index.htmBest of luck with the conversion
Last Edit: Oct 20, 2006 12:45:05 GMT by Stu
