Hi all,
need to get a sd1 prop shortened to fit on my mgbgt anyone know a good place in the cambridge area idealy or i don't mind traveling ......... also need it fast as i am of to the Nurburg ring for the first time with the car on 8th november ....... a mad pannic after a 3 year built .....almost there !!
Oct 19, 2006 10:13:16 GMT
Reco prop in Luton or Dave Mac in Coventry..... ;D They will shorten and balance as well HTH Dom
Oct 19, 2006 10:19:53 GMT
tigran
In rust we trust. Amen.
Club RR Member Number: 142
propshaft need 2b shortenedtigran
@tigran
Club Retro Rides Member 142
Oct 19, 2006 11:15:08 GMT
I heard that reco are good, but man do you play through your ass for it.
Mr K
Oct 19, 2006 11:24:57 GMT
i need a hybrid one that goes from suzuki SJ jeep gearbox to hopefully a vauxhall magnum axle - so this info is realy useful.
anyone any expeiance of doing this? would they want the suzuki prop, and the vaux prop to make one out off? or would they have bits and bobs on the shelf to knock it up with?
sorry about the thread jack! Nick
tigran
@tigran
Oct 19, 2006 11:28:34 GMT
I was told when i rang them that they make it up custom, you tell them what you want they tell you a price.
01582 412 110
Oct 19, 2006 16:24:04 GMT
John (Beardmore) knows all the tech stuff on props...hopefully he'll pop on and fill us in....
Oct 19, 2006 16:26:09 GMT
This is useful stuff!
Oct 19, 2006 16:43:59 GMT
Scholar Engines at Mendlesham in Suffolk turned my Marina prop round in 24hrs (Okay, get the jokes out of the way!), shortened and balanced!
Rover Metro - The TARDIS - brake problems.....Stored Rover 75 - Barge MGZTT Cdti 160+ - Winter Hack and Audi botherer... MGF - The Golden Shot...Stored Project Minion........ Can you see the theme?
Oct 19, 2006 17:46:06 GMT
There are normally plenty of local places that can do this kind of work, just need to look in yellow pages, then give them a ring and pop in if you can and try and get an idea if they know what they are talking about first (most are pretty good).
You normally need to take both props in and tell them the required length and they will sort it from there. When my brother in law got his done (4age, T50 box to avenger axle) it cost around £35 and they did it same day, a few years ago now though
Oct 19, 2006 19:53:44 GMT
where was that rich?
"quote hairnet"
I'm not paying nine pound for a pi$$!
[/quote]
Oct 19, 2006 20:41:26 GMT
Chilton Propshafts, but Barry retired
Oct 19, 2006 21:03:54 GMT
i need a hybrid one that goes from suzuki SJ jeep gearbox to hopefully a vauxhall magnum axle - so this info is realy useful. Put them both next to each other and decide the best place to join together (with a good few inch overlap). Cut them with a hacksaw and measure external diameter if thin one and inner diameter of fat one (your screwed at this point if they're the same size) and make up/ get made a couple of spacers and weld
Oct 19, 2006 22:14:01 GMT
^^^^ No problem doing it yourself, just need to make sure its balanced.
tigran
@tigran
Oct 19, 2006 22:16:22 GMT
How are one piece props compared to usual stuff? Just remembered i have a cossie prop kicking about in the shed.
